Hi please can any1 help I have a 3inch black blank right hand side and 2 inch thick vertical lines on my screen can any1 give me some advisem get rid of t what I can try to fixsy problem im disabled and hopei dont need a screen I had the screen off and looked there r no breakages visible to screen on front or back please help thank you ray
That's typical of a loose connection or faulty LCD cable, thankfully both options are cheap *IF* you know what your doing. I'd have an experienced person re-seat the cable on both the motherboard and LCD panel, if you still notice the issue it may be time to replace the LCD screen (which could/would be very costly if done at a professionals)
SOURCE: Vertical lines in my laptop screen
Check it on External monitor prior to replacing the screen.. If the problems there as well its not the screen..
There could be three different possibilities why you would get a line on your lcd display.
First, it could be a missing signal from the controller IC to LCD driver IC
Second it could be a defective LCD driver IC itself
Third it could be a dry contact in the tape carrier package ( TCP).
Attach an external monitor to your laptop and make it your primary display unit to see if you are still getting the lines if not its you TCP if you still get lines it will need to have either the LCD IC or the controller IC checked and possibly replaced.
There can be 3 possible reasons for this
1)Screen connector cable is loose. You can try to re-seat it and see if works.
2)display card problem. Connect your laptop to an external monitor and see if the problem persists. If it does not then
3)You will need to get a replacement LCD screen.
Hope this helps!
Try using an external monitor,every laptop has a blue VGA connector,just connect a monitor there and check is those lines
disappear,if it does,probably you have a problem with the internal connection of your monitor to the motherboard.
I had the same problem - sent it in to Acer and they replaced the LCD for 500 bucks!
