Toshiba Satellite A215-S7422 Notebook Logo
Posted on Mar 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi i get error message when i'm trying to start a web cam ( CANNOT EXECUTE ''CEC_MAIN.EXE'' )
Mark Gough
Level 3:
President:
  • Master 415 Answers
  • Posted on Mar 09, 2009
Mark Gough
Master
Level 3:
President:
Answers
415
Questions
Helped
156882
Points
1679
What make and model of webcam?
2answers
Aspire 5630 orbicam.exe has stopped working
try to reinstall the drivers or roll back the driver
Hi. I have a Toshiba Satellite L25-S119 laptop. I just bought a Microsoft Lifecam HD-6000. However, when the Microsoft Lifecam application launches I get an error message -> lifecam.exe has...
The first thing to try would be to right-click on lifecam.exe and run it as administrator. If that does not resolve the problem. Then open Device manager. Start->Run-> In the run box type in devmgmt.msc and hit enter. See if the camera has been detected under imaging devices and let me know
1helpful
I have Toshiba laptop with built in camera, but whenever i try to open the camera i recieve an error message 'CEC_Main.exe' reinstall. Kindly help how do i go about.
You also have Kasperkey ?
The error message 'CEC-MAIN.exe' is connected with the Camera Assistant Software,
You are unable to run the camera software because your KIS (Kasperkey Internet Security is blocking it by keeping "CEC-MAIN.exe" in the 'Untrusted File'.
Resolution:-
1) Launch your web browser
2) In the Notification Area (Down by your clock - Right click on the KIS icon and select "Pause Protection" > select "Resume manually"
3) In Notification Area: click on KIS icon elect "Applications under Control"
4) In the "Applications under Control" menu relocate "CEC-MAIN.exe" from the "Untrusted File" to the "Trusted File" - click "OK"
5) > Start > All Programs > CEC-MAIN icon to run your web camera program
Or My computer >> Local Disk (C) >> Program Files >> Camera Assistant Software Folder >> CEC-MAIN icon
Your webcam should now be running
Worth putting a shortcut on your Desktop at this stage .
6) With the webcam still running, then In notification Area - Right click on the KIS icon and select "Resume Protection"
7) Check the "CEC-MAIN.exe" in "Applications under Control" and confirm it is still in the "Trusted File"
8) Restart your computer
2helpful
2answers
Ceccmdll.dll cec-MAIN.EXE HAS STOPPED WORKING
Have you just installed a new security app such as Kaspersky?
If so you could so allow CEC_main.exe in the firewall which should cure the problem.
2answers
The install shield doesn't finish working
Try copying the files on the disc to a folder and run them from there. Open the folder you saved the files in then double click the setup.exe icon and see if it completes the installation. If that does not work then try downloading the files from the radio shack web site.
2helpful
Driver web cam tc115 manhattan
Here is the link to the website with the install discs of all manhattan cams I have also copied the instructions for your benefit.http://www.manhattan-support.com/driver-multimedia-cams.shtml 1. Make sure that the USB web camera is physically disconnected from your computer. 2. Insert Driver CD into cd-rom drive and allow autorun menu to appear. 3. Proceed with installation by explicitly following steps 1 through 3 of the autorun installation menu, restarting where necessary. 4. Connect the USB Web Camera to your PC. 5. Allow time for Camera drivers to be detected and installed. Ignore all Windows logo certification (or similar) messages and proceed with installation. Click on Windows Start Menu and execute the Pharoah Eye software application.note: make sure the camera is unplugged before installing.That should do it good luck,
1helpful
DirectShow amcap sample fail to run my HP web cam.
Normal 0 Double Click on this site
http://www.free-codecs.com/download/AMCap.htm
to download the Free AMCAP Video Capture Program.
AMCap v9.20 AMCap is a small yet fully functional video capture application compatible with Microsoft DirectShow. It is based on the sample AMCap from the Microsoft DirectX 9 SDK. AMCap supports still captures to BMP, JPEG and PNG formats and it remembers your Video Input, Video Standard and Video size settings from previous session. It has some nice features like multimonitoring support, zooming, aspect ratio and deinterlacing features.
AMCap is a small and effictive piece of software and definitely worth trying. Hope this will help. Bud
Intellinav.exe application error
The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
Usually you get this error message when performing a specific task, and if that happens you need to check the corresponding 3rd party's website/support department to see if they are aware of the problem
..a while back symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
So what can you do...? well below are a couple of suggestions:
0xC0000005 - Resolution Suggestion One:
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then I would remove them and see if the error goes away. If it does then send the memory back and get a refund!
0xC0000005 - Resolution Suggestion Two:
In Windows XP Service Pack 2 Microsoft introduced Data execution prevention (DEP), a set of hardware and software technologies that perform additional checks on memory to help protect against malicious code exploits. In Windows XP SP2, DEP is enforced by both hardware and software.
Some software/application behaviors are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation
(such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with Safe SEH must have their exception handlers located in executable memory regions.
Applications that attempt to violate DEP will receive an exception with status code STATUS_ACCESS_VIOLATION (0xC0000005).
If an application requires executable memory, it must explicitly set this attribute on the appropriate memory by specifying PAGE_EXECUTE, PAGE_EXECUTE_READ, PAGE_EXECUTE_READWRITE or PAGE_EXECUTE_WRITECOPY in the memory protection argument of the Virtual* memory allocation functions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offense, contact the vendor for a resolution...
Note: It is possible to "Turn Off" DEP in the boot.ini file but this really would be a last step!
/NOEXECUTE
This option is only available on 32-bit versions of Windows when running on processors supporting no-execute protection. It enables no-execute protection (also known as Data Execution Protection - DEP), which results in the Memory Manager marking pages containing data as no-execute so that they cannot be executed as code. This can be useful for preventing malicious code from exploiting buffer overflow bugs with unexpected program input in order to execute arbitrary code. No-execute protection is always enabled on 64-bit versions of Windows on processors that support no-execute protection.
There are several options you can specify with this switch:
/NOEXECUTE=OPTIN Enables DEP for core system images and those specified in the DEP configuration dialog.
/NOEXECUTE=OPTOUT Enables DEP for all images except those specified in the DEP configuration dialog.
/NOEXECUTE=ALWAYSON Enables DEP on all images.
/NOEXECUTE=ALWAYSOFF Disables DEP. (This setting doesn't provide any DEP coverage for any part of the system, regardless of hardware DEP support. The processor doesn't run in Physical Address Extension (PAE) mode unless the /PAE option is present in the boot.ini file.)
0xC0000005 - Resolution Suggestion Three:
I have also seen this error in the gaming community when folks have updated drivers for their graphics card. If this happens just roll back your drivers.
0xC0000005 - Resolution Suggestion Four:
Microsoft Internet Explorer 6.0 stops responding when you try to open an HTML document or a Web page. Additionally, you receive the following error message:
Access Violation (0xC0000005 exception)
CAUSE:
This problem may occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags. If a SPAN tag is not closed correctly by using the </SPAN> tag, an access violation may occur.
WHY are you using IE6 still??? Upgrade to IE 7 today!
...and that should have now resolved the 0xC0000005 error for you!
Please rate this fixya
3100z software control
I think that to use this nice camera as a "web-cam" is really a wastage!
This fine camera should take the best photos I owned, even compared with my Canon D-SLR.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
