Software tech says it is a connection problem. IP says it is a connection problem. AT&T says it is not a connection problem. IP says it could be a modem problem but that would be unusual. Down load starts, and progress window indicates a down load rate of 1.5mb/s. As the download progresses, the rate starts to slow down. It may take 15 minutes but eventually it gets to about 400kb/s and the line drops. It then requires a power reset of the modem to restart.
SOURCE: can only get dsl if i use landline
Hi, Rob just studied ur problem.Iam a tech which handles this kind of issue. I talk to verizon,at&t,bellsouth,qwest daily for such issues. Well i can suggest u onething u can get the efficient speedstream 4100 series modem which comes with a 1 yr warranty. And also checkout with verizon clearly abt ur distance from the central office.Bcos might be ur dsl circuit may be not technically feasible i:e NTF. For further clarifications plz get back to me.
SOURCE: Router seems to drop connection frequently
What a static ip is, is the ip address that the router automatically assigns to other equipment. (computers, xbox, ect.) Find D-links customer support line for help.
SOURCE: 2701HGB modem - dsl light flashes red
if all the lights on the modem are Green then it means there's no prob with the hardware. just make sure that you're going to use the right WEP key or wireless password. the network name is 2wirexxx, the X is the the last 3 numbers of the SN which can be found on the bottom of your 2wire 2701HG-B.make sure that your wireless switch is also turned on of course. the wireless light on the modem will lit if it is connected
SOURCE: Intermitent DSL/Internet Connnectivity 2701 Router
Hii,
* If you can connect after disconnecting power and reconnecting, it means there is formation of static charge on modem
* Check whether there is any cordless phone or any other satellite devices next to the modem. If so, move the modem 10 feet away.
* If your modem is placed on carpet, please place it on wooden desk
For guest:
Do you see the power is also interrupted while loosing connection? If so try plugging the modem into different socket. Dont waste money for simple problems.
If this doesnt work, please dont rate me down, if it works, please rate me as fixya!!! lol...
Have a nice day!!!
