Zoom X6 (5590) DSL Modem (55900003) Logo
Question about Zoom X6 (5590) DSL Modem (55900003)
Can't connect to 10.0.0.2
This is supposed to be the site of ZOOM's configuration Mgr, thro,which I want to secure my wireless network connection (via Zoom's ADSL X6 router)
However, it doesn't appear anywhere when I ggogle it, as the instruction manual tells me to do
Any help available?
Posted by dwjane on
  • Anonymous May 13, 2009
    i cant access this:
    To log into the Zoom x6 - type into the browseer ; 10.0.0.2
    Thsi will bring up the login page - login: admin
    password: zoomadsl
    how can i do this
  • Anonymous May 21, 2009
    i cant even enter at all this is what comes up
      You are not connected to the Internet.
        The website is encountering problems.
          There might be a typing error in the address. any ideas people thank you
ultimitloozr
  • 489 Answers
Googling that address will get you nothing. There are specific blocks of IP addresses that are not used on the internet. Instead, they are reserved for use in private networks. The addresses in these ranges are not available for use on the internet:
Class A networks: 10.0.0.0 - 10.255.255.255
Class B networks: 172.16.0.0 - 172.31.255.255
Class C networks: 192.168.0.0 - 192.168.255.255
What they are telling you to connect to is your DSL router which must be using the 10.0.0.2 address for it's own web-based configuration tool. If you open up your web browser and type http://10.0.0.2 into the address bar and hit enter, it should bring you to their configuration utility that is built into the router.
Posted on Apr 02, 2009
Netgear extender WN2000RPT
These are a huge pain and I would recommend returning it and buying a Devolo dLan Wireless extender since they can self-configure. If you insist on using the device you have, try these steps:
1. Reset Primary Router to have NO SECURITY (you should be automatically disconnected). Don\'t just reset to factory defaults! If your ISP requires specific router configuration to connect, resetting would erase all of those settings. Simply open the router config site and remove Wireless Security. The best way to know is to Google your Router and Model for configuration instructions.
2. Reset Extender to Factory Defaults.
3. Plug Extender in (if not already done)
4. Connect the PC to the ROUTER (which should have NO security at this time)
5. Confirm that you have connection to the Internet, as well as any network devices.
6. If #5 failed;
6.a. Make sure the old wireless connection (manage connections) has been deleted.
6.b. Close all Network Configuration windows (don\'t know if this matters, but sometimes the refreshed list refused to update with new config settings without this step).
6.b. Scan for available wireless connections.
6.c. Keep doing 6.a and 6.b until the correct wireless connection is shown. In my case, I kept getting "Cielo Secured" instead of "Cielo Unsecured" (or vice versa).
6.d. When the list shows the correct connection and security setting, select it to connect to the router.
6.e. Return to Step #5
7. Now you\'re back to essentially where you were to start, sans security. Close all Internet Explorer pages.
8. Open Wireless Connections again, and disconnect from the Primary Router, and connect to the Extender. If your wireless connection list is showing conflicting Extender and Security information, follow Step #6 until it\'s correct.
9. Open Internet Explorer. You should automatically be thrown into the Extenders Auto Configuration wizard. Follow the Wizard instructions until it\'s finished. When it shows the security settings, make sure that it\'s set to NONE.
10. Once the wizard is done, and you\'ve clicked on the "finished connecting" button in the Extender config, make sure you save the Bookmark as suggested - you\'ll need that later when you add security. Now, check your wireless status.
Hopefully it will show "Internet", not the pesky "Limited Connectivity". Open the Network & Sharing screen to verify there is no dreaded Red "X" between your Extender and the Internet. It may take a few minutes for the Internet status to update.
11. If Step #10 failed, start from Step #1 again, making sure that each device has been configured with NO SECURITY.
12. If Step #10 was successful, take a moment to step back and perform a 2 or 3 minute Chicken Dance in honor of the Computer Gods. .... Or, maybe not. wink.gif If nothing else, at this point you\'ve proven the Extender will work, even if unsecured.
13. Now, go through Steps 4 through 12. This time, though, configure the Router to the security level you wish.
14. Since we\'ve already configured the Extender once, use the Bookmark saved in Step #10 to re-open the Extender configuration site. Click on "Exit" when it opens if it wants to run the Wizard again. It may also guide you through updating the firmware if that\'s necessary. Let that finish before continuing.
15. MANUALLY configure the Extender by first selecting "Connect to Existing Network". If all things are set correctly, it will eventually ask you for the security key for your Router. Enter and continue.
16. This time, when it\'s done, it should have updated the configuration for BOTH devices using the Network Key you just entered. You should see an updated Extender security setting summary screen. Re-connect to the Extender (wait for the status to show Connected, then click on the button at the bottom. The Extender Status screen should be displayed.
17. Open the Network and Sharing screen to confirm there is still no Red "X" between your network and the Internet.
18. If Step #17 was successful, open Internet Explorer and confirm you can access the web. Yippee!!
19. If Step #17 failed, then the auto-config screwed up again. Click on "Wireless Settings", and manually configure the Extender to match what you set on the Router. Return to Step #17 to confirm that resolved the issue.
Fair warning, this will take a long time to accomplish. Netgear in my opinion is the worst brand on the market for wireless!
Why will it not hook to the wireless internet? I have netgear and I have the little thing that plugs in to the computer...
To connect your computer to the Internet via a wireless router, you click the Refresh network list, then Choose your wireless network and then click Connect to your secured Wireless Network, it will asks for a Network Key before allowing you to connect into your wireless network. This Network Key is either the WEP, or WPA or WPA2 Encryption key that is used to configure the Wireless Router. The Passphrase is an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrase that was used to configure the Encryption key in the wireless router. http://www.fixya.com/support/r5270415-network_password_network_address For information on securing your wireless network, configuring the wireless router and configuring the wireless card in the laptop/computer, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Connecting hp712c to hp g7 notebook via netgear wnr 2000?
To connect your computer to a wireless router, you click the Refresh network list, then Choose your wireless network and then click Connect to your secured Wireless Network, it will asks for a Network Key before allowing you to connect into your wireless network. This Network Key is either the WEP, or WPA or WPA2 Encryption key that is used to configure the Wireless Router. The Passphrase is an alternate way to setup the Encryption key.
Wifi on laptop
To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
My netbook will connect to router thro ethernet cable but refuses to connect wirelessly even tho it sees the connection and signal excellento
Network Key (WEP, WPA, WPA2 Encryption key)When youclick Refresh network list, then Choose your wirelessnetwork and then click Connect to your secured Wireless Network, itwill asks for a Network Key before allowing you to connectinto your wireless network. This Network Key is either the WEP, orWPA or WPA2 Encryption key that is used to configure the Wireless Router. The Passphraseis an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in the laptop/computer,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
2answers
How to add apple McBook to secure network. Changed configuration to secure network and apple laptops cannot connect via wi-fi.
The MAC network card needs configuring with the router's security settings ie. SSID and encryption code etc, otherwise it cannot connect to the router wirelessly.
1helpful
2answers
After installing the router it was working fine. I went in to set up wireless security and now the internet light stays red.
Probably means that the security is turned on, if the wireless doesn't work even after you have entered the right password then press and hold the reset button on the back of the router to restore it to defaults - factory defaults just like it was first powered on.
1helpful
My XP computer is a wired connection to the modem. The XP computer is supposed to be a wireless connection to the modem. That said, why is it that when setting up the router, I am instructed to plug in...
It's not really required to plug in your PC via ethernet cable to the wireless router in order for you to configure it. It is however, recommended to connect it via ethernet cable initially so that when you changethe wireless settings on the router you wont get disconnected. Please note, that when you connect your PC wirelessly all wireless settings should match (Wireless Name/SSID, Wireless Security (WEP/WPA keys or passphrase), Wireless MAC Filtering).
3helpful
2answers
Can not connect to internet using wireless
Did you input the WEP key? I will assume you are using Windows XP. So go to control panel, network connections and then go to the wireless connection and then select view wireless connections double click on the one with the highest strength, which should be your 2wire. When it asks for the network security key type in the numbers that are located on the sticker on the bottom of your router between the [########] brackets.
Zoom aDSL modem/wireless router seen but not connecting
Here are a couple of ideas to look at first, assuming you haven't tried them already:
1) Does moving the router help? Sometimes a new DECT phone or a microwave, or even a piece of equipment at a neighbour's house, can interfere with the signal.
2) Does changing the channel on your router help at all? If there are many other networks using the same channel, this might block your own signal.
3) If this does not make any difference, it might be worth checking your security settings.
Top Zoom Computers & Internet Experts
Mike
Mehandi Husain ...
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
