Computers & Internet Logo
Anonymous Posted on Apr 07, 2013
Does anyone know where to get the schematic for the dv6550us motherboard?
joecoolvette
Level 3:
  • HP Master 5,660 Answers
  • Posted on Apr 07, 2013
joecoolvette
HP Master
Level 3:
Answers
5660
Questions
0
Helped
2194833
Points
18014
The closest I come to an HP Pavilion dv6550us, on HP Support, or on the internet is;
Pavilion dv6550tx
Next inline is Pavilion dv6560us,
then Pavilion dv6450us
Not available to the public.
Do have a Block Diagram,
Models that use an AMD processor,
http://www.laptops-schematics.com/wp-content/uploads/2011/07/HP-Pavilion-DV9000-AMD-Notebook-Laptop-Quanta-AT8-Schematic.jpg
1) Socket S1 processor socket,
http://en.wikipedia.org/wiki/Socket_S1
2) Motherboard chipset is an Nvidia MCP51M
Which is the mobile version of Nvidia GeForce Go 6100, or Go 6150;
and Nvidia nForce 430,
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_graphics_processing_units#GeForce_Go_6_.28Go_6xxx.29_Series
Graphics chipset,
http://www.ebay.com/itm/NEW-Original-nVIDIA-Geforce-NF-G6150-N-A2-BGA-ic-chip-north-bridge-Chipset-/271010886762?pt=LH_DefaultDomain_0&hash=item3f1981f46a
Conexant CX20549-12 audio chipset
Realtek RTL8101C Ethernet chipset
Models that use an Intel processor,
http://www.laptops-schematics.com/wp-content/uploads/2011/07/HP-Pavilion-DV6700-Intel-Notebook-Laptop-Quanta-AT3-Schematic.jpg
Uses the Socket P processor socket,
http://en.wikipedia.org/wiki/Socket_P
Both use the Fairchild Semiconductor Industries - FDS6679 - Power MOSFET, and Alpha & Omega Semiconductor LTD - AO4407 - Power MOSFET, in the DC - DC circuit; as far as I know.
Both are Obsolete, but there are cross match examples out there.
(FDS6679AZ for FDS6679, for one)
Indicates HP Pavilion dv9000 series, and AMD; but also matches up to the Pavilion dv6500 series,
http://www.scribd.com/doc/89356925/HP-DV9000
Scroll down. (Zoom In icon { + } at TOP to increase view size,
Zoom Out icon { - } to decrease view size )
Asking for a Schematic, do I assume you are attempting
Board Level Component replacement?
What SMD/SMT IC component are you trying to replace?
(Surface Mount Device/Surface Mount Technology. Integrated Circuit)
Motherboard chipset info, and processor socket info, for processor upgrade.
Same thing for Ram Memory upgrade.
It does use DDR2 Sdram (SO-DIMM), and at 667MegaHertz, to my knowledge.
What usually goes bad on the HP Pavilion dv2000 series, Pavilion dv6000 series, and Pavilion dv9000 series of Notebook PC's?
The cooling for the graphics chipset is inadequate, therefore the graphics chipset overheats, and partially melts the Solder Joints in the BGA surface mount.
Resulting in no graphics.
Power MOSFET's in DC - DC circuit go bad.
Continued in Comment
  • 6 more comments
  • joecoolvette
    joecoolvette Apr 07, 2013
    Intel motherboard,http://www.ebay.com/itm/HP-DV6500-6600-6... (Motherboards shown are for Reference. Not advertising for seller nor website)http://mayohardware.blogspot.com/2010/04... P.MOSFET info,http://jp.mouser.com/Search/Refine.aspx?... http://jp.mouser.com/ProductDetail/Fairc... http://jp.mouser.com/Search/Refine.aspx?... http://jp.mouser.com/ProductDetail/Diode... http://www.youtube.com/watch?v=3NN7UGWYm...
  • joecoolvette
    http://www.realtek.com.tw/products/produ...
  • joecoolvette
    Hmmm, had I have clicked on your user name, and looked at your account, I could have seen previous questions asked, lol!http://www.fixya.com/support/t17549112-h... It's either the FDS6679, or the AO4407, or both. Also look at the second photo down on the Mayohardware link. Has the AO4407 circled in Yellow. Look at the small rectangular object to the Immediate Right, with the dark wide band in the middle of it. That is an MLCC. Multi-Layer Ceramic Capacitor. It is SMD/SMT. There is one above it, one above that one at the Top; one to the right of the Top one, and one to the right of it. (Placed vertically)........There are also 4 smaller examples to the Bottom/Left corner, of the AO4407. Here is an example; Rated at 4.7uF (Microfarad), and 16 Volts,http://jp.mouser.com/ProductDetail/TDK/C...
  • Anonymous Apr 07, 2013
    Thanks for the comments Joe. At this point I have not yet figured out which component(s) is (are) bad. The only thing I know is that the power from the AC adapter reaches the motherboard but not to the pins of the battery connector and beyond. I can measure the voltage to the connector point on the motherboard and cannot go beyond. I'm suspicious to TPC8111 but am not sure. That's why I'm looking for the schematic at least for this section of the motherboard to go forward.
  • joecoolvette
    joecoolvette Apr 08, 2013
    Field Effect Transistor / Silicon / P Channel MOS type / Lithium Ion Battery Applications ->http://datasheetcatalog.com/datasheets_p... Plus click on the blue - TPC8111 datasheet - in; Download TPC8111 datasheet from TOSHIBA. In otherwords a Power MOSFET.......-> Notebook PC Applications / Lithium Ion Battery Applications..........What lead you; is leading you, to this chipset? Looked burned?........Just curious.....
  • Anonymous Apr 08, 2013
    No it does not look burned ... but, both the input and output voltages (source and drain) are tied to 0V which is not right,unless, the feed to it is broken. This is where I am stuck at and need the schematic for .
  • joecoolvette
    Not indicating I know anything....Just using logic, (Or what I believe to be; Ha!), and asking; 1) I'm guessing you are referring to a schematic of the motherboard, and not of the TPC8111.....2) I, in just wondering......if you know which pin is the feed, and it's not receiving voltage, then what component is next in line for it? Going up that circuit trace, from that pin; what component, and lead of component, is it connected to? I would think an MLCC. Before it an SMD fuse..........HOWEVER......it looks by statements made, that you have board level component skills, while I do not.........That's why I'm just asking........
    1) You are right ... I do have the schematic for TPC8111 and am looking for the motherboard schematic. 2) I'm not sure which pin is the feed and which one the output. But I know that the D and S should not be at the same potential, especially 0V. Also, it is not easy to trace the signals on the motherboard, at least with the magnifying glass that I have. ... it is my first time I'm dealing with a motherboard designed by someone else ... I do my own boards; not as complex as the motherboards; and since I have the schematics it is easy for me to troubleshoot them. In here, had I had he schematic it would be much easier to handle ... Thanks for your comments anyway. I still think that I need to find the schematic for the motherboard to be able to have it fixed ...
Does anyone know where I can get a Schematic diagram for a Shuttle MV43 v3.1 Motherboard
If this was damaged 'In Transit' contact the company you bought it from and they may be able to supply you with a replacement. The damage was possibly due to bad packaging at their end or damage while the delivery company had it.
1helpful
Front panel wire installation guide
Hi Angela,
Most of the connections are pretty standard for MB's.
This should help you.
Thanks and don't forget to rate:)
Gary
Front panel pin out for dell jc474 motherboard
this a matter that anyone need a service manual with schematics, this information is NOT available for free, Normally you need to pay for get schematics, and see your answer. I am sorrry
God bless you
2answers
I have a 3 tr old hp pavilion dv6550 laptop with
Yes, you can replace your worn out motherboard, but it will cost you around 300-400$. In my opinion it doesn't worth this money. You could buy a Toshiba Qosmio. There are several models and you could pick a decent one from them.
If you need further assistance, leave a comment. Cheers
1helpful
I just need the ms 7050 version 2.0 schematic
Usually schematics are not provided. Try requesting the manufacturer or visit http://www.devicemanuals.com . May be you find it. ([email protected])
Schematics for Sony VGN-N130G
find out what kind of motherboard you have and google the schematics. i did this before and it worked
Motherboard Schematic
happened to me, just put a straithrough wire or bridge it and dont plug your modems power supply in next time =!
2answers
T43 motherboard question
hi, usually the schematic diagram comes with the unit, or u will nneed to fetch the manual.. let me know
2answers
What manual...link available?
As far as the schematic for Compaq MoBo's good luck...I can't recall ever seeing a sheet for just a Compaq board, only systems. (I think that board was made be HP so maybe searching that way will yield results) You might get lucky here: http://www.eserviceinfo.com/ They have Compaq system schematics, maybe you can find one that uses that MoBo and has the info you need. Good Luck, El Duderino
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
