SOURCE: Unlocking my Model 32f531t television without a remote
rca32f531t
to reset parental password : turn off tv / simultaneously press and hold volume - on the
front panel and clear on the remote for 5 seconds
then just enter a new password next time your in the parental menu
so you will need the remote to do this
electech
SOURCE: Samsung Hitron TV 488S - All features are locked, cant operate it at all.
I also accidently locked my Samsung TV. I unplugged the power cord and powered up after a minute or so. Set was un-locked after after power up.
SOURCE: Hello, I have a General
Allow me to try and assist you based on your situation.
Most FREE channels went digital, more and more will disappear from the RF spectrum as digital moves into play. This tv is by far not digital thus it uses RF "radio frequency" that is transmitted from a tower to your rabbit ears then converted into the tv to make a picture and sound.
Here is a suggestion that you may consider, will not break the budget. Radio Shack carries a digital set top box that hooks to a antenna thus down converts the digital to analog for you so you can enjoy far more then 6 channels without having to pay the cable man or satellite tv company for your local stations.
Here is a link to the box I am talking about http://www.radioshack.com/product/index.jsp?productId=3150939
This box will help you get those channels back, will get you watching more TV.
Now for the remote issue, This box comes with a programable remote that will work for your tv so it kills 2 birds with one stone. You could also order one from remotes.com or 1800-remotes if you like.
We do hope this information does help you with your problems.
Thanks for using Fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: I accidentally turned on the
Hello
To turn out FPA lock with RCA TV, you must have its original remote control handset. If you haven't one, just buy a new one of borrow it from your friends or relatives, who own the same model of RCA TV. After unlock, you can use any other remote control. If you are using the original remote control, do the following to unlock it.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
SOURCE: Child lock is on,no remote, need owners manual/Magnavox CRT ms3442/17
Is this the manual you're looking for.
http://shop.retrevo.com/m/search/aproduct?c=1041&m=277927&rt=pd
Instructions
Locate
the manual for your television. Though slightly embarrassing, accidentally
turning on the child lock to a TV is a common problem. The section In the
manual about how to set the child lock feature will also explain how to unlock
it.
Try
a few "universal methods" for unlocking the child lock. Some
televisions have a universal code built in for disabling the child lock --no
matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
Turn
on the TV and grab the remote. In most cases, you will need the original remote
to unlock the TV if you aren't sure of the unlock code. If you don't have the
original remote, you will need to purchase one.
Look
at the screen. If you see a blank screen with a red key on the bottom of the
screen, press 'Function' and 'Mute' at the same time. This should unlock the
channel. This is an option for people who want the TV to stay locked but, want
to be able to bypass the lock to watch a certain show or channel. All other
channels will remain locked and the TV will fully lock when it is turned off.
Unlock
all of the channels on the TV by entering the factory reset code. There are
three main reset codes that TV manufacturers set. These are 0711, 6688 and
3308. Try each one until you find the one that works. This will reset the TV to
original factory settings. When you do this, you will loose any information
that you have stored in the TV, such as favorite channels, automatic timers and
the clock. You will have to go through the full initial set up.
Call
the technical support service number in your owner's manual if none of those
codes work. A technician can help you troubleshoot the television because the
problem may not be the locking control. When you call, make sure that you have
the model number and serial number of the TV.
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
The Control Lock (child lock) is on: To prevent accidental operation of the washer or alteration of the cycle settings, press and hold the lock symbol until you hear 3 beeps and ?LOC? is displayed.
To cancel, press and hold the lock symbol until ?LOC? is no longer displayed. To put the control into control lock you do the same thing.
