20 Most Recent
Disney Lightning McQueen TV Questions & Answers
My lightning McQueen tv wont change channells
1= test the selector, and clean it and repair or replace it if is mechanical or digital2= tuner dirty, and clean it or replace.3= see if the cable coming from the antenna or cable is loose or broken, or terminal damaged. and repair or replace.see the diagram for tracking the signalGod bless you
How do i program my tv too play dvd player
The TV remote should have a source button on it, you need to press it and find the scart socket or hdmi connection, it should display a list of the connection that are use for your TV. Some times you can use the power on on the DVD, so have your TV on then switch on the DVD and this may change the TV to the input that you have the DVD connected to automatic-lay. If you are using a TV arial for the DVD to connect to the TV then you need to tune the TV to the channel the TV is using I think in most cases it is channel 21 on the TV.
How do i connect a dvd player to the tv?
Behind DVD player you will have sockets
(red -Audio
white -Audio
yellow- video)
Same set of sockets will be there behind your TV also.
Please connect the Audio video cable correctly accordingly to the colour.
Now your DVD player is coonected to the TV. You can start using your DVD player
Thanx
Lost remote need code for universal remote
since most of the disney TVs are manufactured by memorex company ..... from your universal remote control's manual check the codes for memorex brand & try it .... if you don't have manual for your universal remote then from this link
http://www.remotecentral.com/features/remotes.htm identify your universal remote & in that check codes for memorex brand & try it .... while searching answer for your question i have found that many people have same problem that is code for universal remote ..... but they never got right answer ......... & also neither same original remote control nor equivalent remote control is available (spare ) ...... so in case if you don't get right code then consider selling of this TV & buying new tv ...........
I am writing beacuase the
No,these tvs are spacially made for the Disney Corporation for awhile.The tvs are not in the market anymore.The tvs are in cheaply prices poorly made is was a fad,so no recall.Most of these tv used last like 2 or 3 years,than have problem or completely dead not worth the priced go get it fixed.
Onn roku TV screen blacks out
I"m guessing it's the TV, chances are it would loose sound as well if it was the streaming service. Are your backlights staying on when the screen goes black?
