Remove your drain pump and check for lint and debris.
Remove 2 phillips screws at the back corners of the control panel/
Pull the panel forward and raise it up then backwards.
Unplug the lid switch wire harness.
Remove 2 metal clips on the right and left rear of the cabinet. They hold the cabinet to the back panel.
The cabinet will then lift off.
The pump is attached to the motor with 2 hoses and 2 metal clips.
Removbe the hoses, then remove the clips. Remove the pump and inspect it for a clog.
While the cabinet is off, inspect the wash tub for a garment stuck near the drain hole from the tub to the pump hose.
Reverse the above procedure to re-install the cabinet.
Remember to plug in the lid switch.
where is the drain pump?
