SOURCE: Blank Scan from HP Scanjet 5590 Flatbed Auto Feed
Scanning is possible in 'Text' mode and 'Picture' Mode. In text mode, which is simple 'Black & White", this can happen, particulalrly if the text is in color. Either you increase the contrast settings or scan the document in Grey/color and convert it to B&W using the software. By this you need not check if there is output!. ( I am assuming that otherwise the scanner is performing okay). File size in B&W is very small as compared to Grey/color.
S. Mohan
SOURCE: HP ScanJet 5590 ADF doesn't engage
cannot possible to install in vista using the CD of scanjet 5590
SOURCE: Hp scanjet 5590 error in
I downloaded the following files from HP's website
setup_full_5590
setup_emc_5590
col10862
cit207355-hpcom-patch-v8
hpinstantshare
and followed the procedure that i found on the web at hppt://hpanswers.blogspot.com/2008/03/unexpected-internal-error-has-occurred.html
wich give full instructions on how to cleanly remove the hp software and what files you need to run to help fix the problem.
this is a fix but it is has not got my scanner working the way that it used to but it is working a lot better that it was.
Thanks
Sproket
SOURCE: HP ScanJet 5590 and OS 10.3.9
Forget about the HP software. It's useless in OS X. Get a copy of VueScan and use it instead. http://www.hamrick.com
