Wash cycle is ok but when it finally reaches the spin cycle in stays there and will continue to spin for hours if you go out.
SOURCE: zanussi zwf1211w
are the water supply taps fully on ? check that it is filling quick enough. let my know how you get on. also is it heating the water?
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
SOURCE: Zanussi F1245W not spinning, it tumbles a bit then
Hi airflow_grp
sounds like you have the same problem with your machine, if i get a fix ill post you the solution, on this site. .........andy
SOURCE: I have a Zanussi Aquacycle
Hi.
If the machine is filling up, then cycling and draining, the
problem is usually the belt. The belt is reached disassembling the appliance . If the belt is OK the problem is usually the motor or the motor control unit, which is a sealed electronic module connected to motor and to control board and located inside the washer. If the motor
has volts and does not turn, then the motor must be replaced. In some
less common case the control module itself may be responsible. Motor assembly and belt are located at the back of the drum and get accessed disassembling top and back of the washing machine.
If the machine does not go through the cycle, but it starts draining from start, then the problem is overfill detected. In that case check the drain system, the drain hose, the inlet valve and the pressure switch.
Regards.
Ginko
SOURCE: My Zanussi F1245W Wont Drain or Spin
what you do mate is make sure off,take out the drain pipe from the back.,lay down drain pipe flat to the floor as possible..i use a paint roller tray to drain in to..have a bucke t near by 2 put excess water in..hold up drain pipe whilse doing so,repeat untill drained as much as..then lock will release..set program back 2 spin if working.should work for you!
