Zanussi F1245W Front Load Washer Logo
Dave walliams Posted on Apr 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Zanussi zwf1421 Started machine on a 60 economy wash, after 30 mins the machine stopped in the middle of the wash cycle, the drum appears to have water in it,seem to be unable to move the cycle on to the next stage of the wash either ?
mike cooper
Level 3:
  • Master 884 Answers
  • Posted on Apr 28, 2012
mike cooper
Master
Level 3:
Answers
884
Questions
Helped
404866
Points
1991
Thermostat or heater most likely causes. Does timer button move round without doing anything? Timer knobs on Zanussi notorious for breaking off inside.
5 Related Answers
douglas smith
  • 1462 Answers
  • Posted on Mar 27, 2007
SOURCE: the Washing Machine fills and then empties with not running a wash cycle
possible a pressure stat fault. some pressure stats have a too high water detector which turns on pump
Anonymous
  • Posted on Apr 28, 2007
SOURCE: Drum is not moving
It sounds like the drum drive is broken ... could be a belt at the back of the machine or it could be gear driven ... most likley a belt... take off cover on back of machine to see if the belt is broken and replace if necessary. Also could be pump but that is probably the last thing to go wrong pumps rarely ever fail.
Anonymous
  • 101 Answers
  • Posted on Apr 23, 2008
SOURCE: zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
lsteward68
Raymond Ramirez
  • 333 Answers
  • Posted on Apr 27, 2009
SOURCE: loud banging in spin cycle zanussi aqua cycle
if you can get the front plate off you will probably notice that the drum stabilizer roller has either fallen off or is damaged. This part is replaceable and should be no more than 20 bucks.
Anonymous
  • Posted on Jan 12, 2010
SOURCE: zanussi aquacycle 1000 washing machine spin problem
My zanussi aquacycle 1110 sounds like it is about to take off when it goes onto a spin cycle. Does anyone know what it could be? The big black spings are still in place inside the washer that hold the drum. It also rattles more than normal as well. Thankyou
1helpful
Washing machine humming but nothing else :(
if you watch carefully, the end light flashes and then stops, and then flashes again... how many times flashes?
Put my washing on at a 60 degree wash for 1 hour 40 mins. Went back to machine several hours later, there was tiny amount of water on floor and machine had water in it but the wash had not progressed any...
Sounds like a blockage perhaps the filter needs cleaning or pump blades jammed...If its a Hotpoint then filter is middle of sump hose connected to the drum....
Hi The white load program on my washer has just started to stop at 1 minute to go and appears to just continually cycle on the rinse stage. The coloured cycle works fine. Could you please advise?
Hi you dont mention make and model but I have come across certain brands Aeg Zanussi that wont unlock until the drum temperature is below 50deg c remaining on the last min until that happens. This can be caused by a blockage in the drain system ,pump.filter or hoses.this causes the wash water to be retained through to the end of the rinses. the higher temp of the white prog may be hot enough for the door unlocking to be delayed. A faulty door lock can also give the same effect(affected by the longer prog and temp). also check the inlet hoses if hot and cold are not the wrong way round. good luck
Zanussi aquacycle 1200 smells coming from between the drum and casing.Suspect it is caused by a build up of slime etc.
1. Set the washing machine on the highest water level, temperature on hot and the wash cycle to normal.
2. Fill a gallon jug with hot tap water. Once the cycle begins, let it run for a minute or two, then stop the cycle, open the lid and slowly add the gallon of hot tap water. Don't overfill — you just want to raise the water level so that it is able to reach and clean the inside top rim.
3. Add 2 to 4 cups of household chlorine bleach and restart the cycle. In a couple of minutes, stop it again and just let it sit for at least 30 minutes. Afterward, let the cycle finish, and open the lid to air out the inside.
I got it from this link: http://answers.yahoo.com/question/index?qid=20060827101905AANuYg4
and here:
http://deseretnews.com/dn/view/0,1249,600124768,00.html
Zanussi washing machine
Filter can be clogged, pump can be dead or water outlet clogged.
1helpful
2answers
Zanussi wdj 1094 washer dryer
possibly the motor brushes are worn, the clicking is the pcb relay changing the motor direction.
Top Zanussi Washing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Mike Cairns
Mike Cairns
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
