Get a small pin and insert it in the reset hole on the side or bottom of the device. It will format the disk, erase it and reset it to factory settings. You lose everything, but can reinstall it. First open up the drive and copy all songs to your disk or a flash drive, perform reset option then reinstall all music over.
System files might got corrupted. The best way for you to do is to reformat the MP3 Player. Hook it up on
your computer's usb port. Right click your windows START button and
choose Explore. It will open the windows explorer. Look for the drive
letter associated with your MP3 player, right click on it and choose
Format. Do a quick format and after that, you should be good.
there is a reset button in the mp3 player either in the bottom or in the top of the mp3 player gently push it with sharp object and reset ur device which will free the system file from error and u can now turn on the player and transfer songs via usb plugged into the pc. enjoy the mp3 player great sound and features......
1.download the appropriate firmware from here2.press and hold reset button for 2 seconds 3.run the firmware updater 4.press and hold "volume -" button while connecting to system. 5.the updater will detect the player and it will upgrade the firmware.
To reset you need to have MP3 switched on, THEN hold the off switch for 10 seconds.If this fails to reset.You may have some corrupted music files
sitting on the harddrive.email [email protected]
if you still have problems as i had the same issue and found a workaround.
