20 Most Recent Thomson Lyra PDP2842U MP3 Player Questions & Answers
u may have a soft wear problem
Thomson Lyra... | Answered on May 15, 2014
Can factory defaults be restored to Thomson Lyra 6675
Thomson Lyra... | Answered on Jun 10, 2011
It looks like you need new battery.
Thomson Lyra... | Answered on Dec 09, 2010
Deleting Files,Pictures,Videos,Audio
Books, Apps,etc. from MP3 Player/Ipod
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,
right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Be careful and do not delete files needed to operate your MP3 player.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
Thomson Lyra... | Answered on Aug 10, 2010
There may be virus in USB.
Thomson Lyra... | Answered on Jul 06, 2009
lyradj@thomson.net contact the vendor with this e-mail address. They can advise further.
Thomson Lyra... | Answered on May 28, 2009
This unit is actually produced by RCA. If you go to their website you can download Firmware, and Software to update the unit. You can also try to do a "reset". There is a very small button on the bottom, if you press this with a pen and hold it for about 3 seconds it may start working again.
Thomson Lyra... | Answered on Apr 05, 2009
There is a free program called Media Monkey - it will convert WAV format to Mp3 (actually, it will convert any non-protected music file type - it's very dynamic). It may take a while to figure out how to do the first one, but it will get easier after that.
First, you have to plug the Thomson in to your computer, double-click "My Computer," and then double-click the icon of the Thomson. There should be a folder called "Voice or "REC". If it doesn't show up, select in the window: Tools --> Folder Options --> View --> select Show Hidden Files and folders. Now the right folder should show up. Then, drag the WAV recording to your desktop (or your "My Music" fodler - whichever works best for you), and the computer should make a copy of the WAV recording onto your computer.
Now open up Media Monkey and it should, after several minutes find all music files on your computer, including the WAV recording. Then right-click the WAV recording, and it should have an option to covnert the file type - convert to mp3, and you're done.
-Tha Mp3 Doctor
Thomson Lyra... | Answered on Mar 22, 2009
To reset you need to have MP3 switched on, THEN hold the off switch for 10 seconds.If this fails to reset.You may have some corrupted music files sitting on the harddrive.email strongjonn@aol.com if you still have problems as i had the same issue and found a workaround.
Thomson Lyra... | Answered on Mar 02, 2009
ok plug your mp3 into your computer wait for it to process. then goto Start>My Computer and then the Drive for the MP3 should be named for the Device and then open open it and goto the music files and remove the songs that you do not need. This usally works for most MP3 Players. If this helps please Rate me thanks
Thomson Lyra... | Answered on Jan 24, 2009
Code 10 means it cannot find the drivers.
Most of the newest MP3 players are designed to run with Windows Media Player version 10 or higher, this contains all of the drivers necessary for installation and recognition.
Best of Luck.
Please RATE my solution BELOW.
WELL I DID NOT FIX THE PROBLEM YOUR MP3 JUST WONT TURN ON AS SOON AS I PUT ANOTHER BATTERY IN IT WOULDN'T PLAY I ONLY GOT IT ON CHRISTMAS AND NOW IT WONT TURN ON
Thomson Lyra... | Answered on Jan 05, 2009
Hi Norman, i'm from Spain, but i have the english manual in pdf. If you want send me your mail to Hafler@telefonica.net, then i send you. Greetings
Thomson Lyra... | Answered on Dec 14, 2008
Mine froze on the blue screen when turned on. BSOD???
Plugged it into the USB on computer and it all came good.
Thomson Lyra... | Answered on Aug 26, 2008
dear rthawk
I reckon there could be a driver issue here with your MP3 player. I have seen a case with a vendored model that was aquired from Tesco, and in that situation, a driver file was accidently deleted from the MP3 player. Now this matter (if this is what happened to you) could be difficult to deal with, as how do you get the driver file back on to the MP3 player if your computer will not allow it to recieve files? The answer here could be to run the "found new hardware wizard" which is in windows xp under START>MY COMPUTER>CONTROL PANEL>ADD NEW HARDWARE. when you click on the add new hardware, ensure that your MP3 player is plugged into to a USB port which is in good working order. Now if you computer is asking you for a drivers disk, then insert the CD into a drive bay (CD that would have been despatched with your MP3 player) and follow the commands.
Now if this still does not resolve your problem, you could always try to format your MP3 player using the utility within windows. To get to the utility you have to follow this. START>MY COMPUTER>right click on MP3 player drive letter>PROPERTIES>FORMAT VOLUME. This will format the entire USB MP3 player and create a partition on it which can either specified as FAT32 or NTFS, and will format it accordingly to which of these you choose. HOWEVER, a slight word of warning here, doing this could inadvertantly kill off" your player totally, as to the point it could only then be used as a pen drive instead of a MP3 player. It is possible that your computer (and any other computer for that matter) would only recognise the player as a pen drive, but even here, i would say it is still possible to flash your MP3 player and force the driver file back onto the player.
Now if this has still not worked, there is a danger that you could have corruption within your own computer, so here, you can try using another computer to see if you have the same problem. If your coputer ios found to have an issue, then this is mostly likely to be software based, and specifically relate directly to the system registry, as this is where the majority of data corruption will occur. Now if this proves to be the case, just swan off your operating system after backing everything up, format your drive, and re-install windows.
Now before attempting any of this lot, i would suggest by starting off at checking things like blog sites and forums in order to see what other people have done about the issue relating to your manufactured/ vendored model of MP3 player, but the list of potential solutions above are things that I have done, and these seemed to work for me, but like I say, go and check those blog and forum sites and then choose the best solution based on what the majority of people EXACTLY say.
Now whichever of the above approachs you take, or even if you find something else entirely, please do leave me feedback on this, as so i will then have knowledge about hw best to deal with this in the future.
For now though, i do wish you all of the best of luck on this one, and do take care of yourself,
kindest regards,
Yours sincerely
Oz
Thomson Lyra... | Answered on Jun 28, 2008
http://downloads.thomson-europe.com/en/Download.html?model=PDP2842 all the software you need is on this page i know have just used it
Thomson Lyra... | Answered on May 26, 2008
You can contact TIVO UK through phone, here are the contact information:
Phone number: 08702 41 84 86
Hours of operation:
Monday - Sunday, 08.30 - 23.00 GMT.
Their website is located in this address: http://www.uk.tivo.com/3.0.asp
Thomson Lyra... | Answered on May 11, 2008
Thomson Lyra PDP2842U MP3 Player Logo
38 questions posted
Top Thomson Audio Players & Recorders Experts
Damen Wong
Damen Wong
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Thomson Audio Players & Recorders
Most Popular Question
get radio just re formated
  • Audio Players & Recorders
