The screen continues to show "paper jam front rear" and refuses to print even though all paper has been removed from the jammed area
SOURCE: document jam
I had this totally annoying problem this morning. After looking for any obvious paper jams or small bits of loose paper, I tried several fixes: 1) open front cover, release levers that hold white rollbar in place, roll the bar forward to make sure nothing is stuck behind it, snap levers back in place; DID NOT fix the problem; 2) open top cover, remove print cartridge, look for jammed paper bits, close cover; DID NOT fix the problem; 3) unplug the machine, wait a few minutes, turn machine back on; DID NOT fix the problem. I even unplugged the machine, opened ALL the covers, turned the machine upside down and shake it to see if any paper clips, staples, or other objects have fallen inside the machine; DID NOT fix the problem. FINALLY, I pulled the paper feed tray forward, reached down to the feed rollers, twisted them a few turns, put paper back in the machine, and the "paper jam" message disappeared! This may not work for everyone, but it worked for me today, so I hope this helps someone out there to have a better day.
SOURCE: Paper jam
The various parts that open up to allow access are monitored by a micro switch. Switch the machine off and open all the access points locate the switch and make sure it is freely working and the connections are all in place. Then come back
SOURCE: can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
SOURCE: Continual paper jams in rear of printer
If the paper is jamming at the exit rollers, you will be need to clean the rubber on the rollers. It gets shiny and does not grip the paper to take it away.
SOURCE: REPEATED REAR PAPER JAMS-BROTHER INTELLIFAX 2820
Try making prints or copies with the rear door open. If it does not jam your fixing unit (hot area) is functioning properly. With the rear door closed try again making copies or prints. If it jams it's most likely the exit rollers acting up.
1. I've seen the exit sensor break on these units and sometimes the drive gears wear and do not feed properly.
2. If using after market toner or refills this may also coat the exit roller with a film which prevents the exit rollers from feeding parper out by reducing the friction of theses rollers. Clean with fantastic untill cloth does not turn black.
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
?· Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
?· When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
?· When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
?· Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
