After it agitates, and the water drains out, when the timer advances to spin cycle, the timer advances, but no spin. I checked the tubs, no obstructions, coupling between the motor and drive unit is perfect. The wires and capacitor are OK.. Now if i list the lid, and then turn the tub manually, close the lid, it now spins. No matter how many times I raise and lower the lid, till the spin cycle is done. Restart the washer in the spin cycle and it still spins. BUT start the washer from the beginning, let it agitate, etc., when it comes to the spin cycle, no spin. Unless I turn it by hand again.
Following your description the problem is with the lid switch.
Get an access to it and find out whether something prevents his smooth movment,its has a loose wire connection or the switch is malfunction and should be replaced.
you can check the direct drive coupling between the motor and the transmission, if the coupling is good and not broken then you have a transmission problem
Hi, this can be two issues here. Number one would be a busted belt. The next issue would be a drive assembly failure. this consist of the clutch and gear case(transmission) assembly. I would check these areas out. you will find the problem here.
what this function mean is that there is a blockage on the water flow out from the pipe .
what you will have to do to fix up this problem with any replacement of part first of all put off the power supply connected to the washer then bale out the water in the drum then trace the pipe to the drain remove all forms of dirty blocking the pipe (water drainage) with this the problem of undrain water will have been solve.
Hello there: If your cycle does not complete or The cycle doesn't advanceWhen the cycle should advance, it's probably the timer or a cold-water supply problem:It's
the timer, if your washing machine fills with water and begins
agitating, but the timer never advances--or if the washer is in a spin
cycle and the timer won't advance. Then you need to replace the timer. It
may be a cold-water supply problem, if the washing machine fills with
water, agitates, drains, and spins, but then doesn't fill with rinse
water. than check the cold water supply line and the filter
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
If the Washer is stuck in spin then either the timer or a cold-water supply problem is causing this :
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance, then you need to replace the timer.
Do rate the solution as FixYa and revert for further clarification.
* It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
* It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
