Televison & Video Logo
Anonymous Posted on Jan 12, 2013
Channel is move automatic sharp lc22l50m - Televison & Video
Anonymous
Level 3:
  • Master 1,238 Answers
  • Posted on Jan 12, 2013
Anonymous
Master
Level 3:
Answers
1238
Questions
0
Helped
329899
Points
3603
You have faulty and stuck up channel button on TV panel.
1helpful
Can't change the channels aquos tv i need to change the channel to 4 have no remont
Press the "Menu" button on the front of your Sharp TV. This will allow you to access the menu for your television without a remote. When the menu appears on screen, use the "Channel" buttons to move up and down, the "Volume" buttons to move left and right and the "Input" buttons to select items.
https://www.techwalla.com/articles/how-to-program-a-sharp-tv-without-a-remote
Sharp lcd tv lc22l50m-bk error code k-123 apper on disply
If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of many popular brand TVs and other devices are given. Error codes and LED blinking codes too are there. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
How do I tune the channels on a sharp cx34g3 TV. thanks
Yes, according to the manual, press PRESET, then VOLUME DOWN to automatically set all the channels the TV can pick up. Sharp has the manual for this model at http://support.sharp.net.au/CustomerCare/Operationmanuals/default.asp
Sharp TV-Remote not working correctly
You will need to complete a channel scan from the tvs menu. I assume you have basic cable and that your cable company is still providing analog channels for you to be able to pick up any transmission on this telvision with the digital changeover and all.
Sharp HGTV will not show channels after EZ Setup
Well the advise I have for you is the TV is not connected to a good antenna or something is fouled with the sgnal or tuner or both.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
CAN'T CHANGE CHANNEL MANUALLY AND REMOTE DOESN'T WORK
Hi again,
Many thanks for the wonderful review and the rating.
Good luck and kind regards.
Thank you again for using FixYa.
2helpful
Auto Tuning Channels on LC20B2MA Aquos TV
 Automatically tunes in and preset
receivable TV stations.
Make sure the antenna cable is
properly connected.
1 Press MENU (PRESET-1) on the
upper part of the LCD TV set for
more than two seconds. The
AUTO mode screen appears.
2 Press VOL (–)/(+) (PRESET-2)
on the upper part of the LCD TV
set.
All the TV stations in your area
that can be received by the LCD
TV set are automatically preset.
3 The screen shows whatever is on
channel 1 when full auto channel
preset is finished.
Sharp 21-lv009
Good day.
Go to menu
select channel set up
select auto channel set up
chris
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
