SOURCE: monitor
hi auntie
while the monitor is OFF press and hold the MENU key,switch ON the monitor while still holding the MENU key and voila it is unlocked
Hope this fixes you
SOURCE: AOC monitor 2436vh does not
The "Best Solution" fixes a problem that is unrelated to the original poster. anononline19's solution is to fix the entire OSD being locked (displays OSD Locked when the menu button is pressed).
Original poster's problem can be fixed by changing your graphics card's "overscan" settings.
Overscan on ATI cards:
http://nigelt.wordpress.com/2009/09/21/overscan-options-in-catalyst-9-9-on-windows-7/
Overscan on nVidia cards is currently not supported.
SOURCE: i have sapphire ati radeon
In order to connect a graphics card with a monitor using HDMI theyu both must have a HDMI port.
While your graphics card does have a HDMI port, it appears that your monitor does not.
You will not be able to connect them with HDMI.
SOURCE: AOC 2036sa 20 Inch Monitor Tft Lcd red power led blinking
due to high voltage my aoc 2036sa moniter is crassed.Where is the problem?
