Power supply is OK, there is no inverter on signal from main board, only red power led is flashing
Due to high voltage my aoc 2036sa moniter is crassed.Where is the problem?
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they might be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions even something as small as an electrical fan and its lead can cause this problem or just replace them they could be faulty a computer needs all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free restart your computer then reinstall it this should activate found new hardware wizard
hope this helps you
