20 Most Recent AOC FOVI F19S Monitor Questions & Answers
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps you
AOC FOVI F19S... | Answered on Oct 20, 2011
Pressing and holding the menu key for a couple of seconds shoul do the trick.
Please come back and leave a rating/testimonial if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
AOC FOVI F19S... | Answered on Jul 30, 2011
OSD popup no signal If you are getting a message that says something like"Check cables" "no signal detected" or something like that,it is likely that your monitor is operating correctly. I would suggestchecking your cables, make sure that the computer is turned on, and if thatdoesn't help, check if your monitor has VGA, DVI, or HDMI inputs. I amthinking that your monitor may be trying to display from the wrong source. This is what a VGA (analog) cable looks like. VGA cables aretypically blue.tgvern_4.jpg
Another common connection that is used is a digital HDMI (left) or DVI(right) connection. DVI cables often have white endconnectors. How your PC connects to your monitor will determine thesource mode you want to use on your monitor. (Obviously this is the cableview but the connection on the monitor itself will look similar.) tgvern_5.jpg
If none of these tips helps, I would suggest hooking the same monitor up to adifferent PC or laptop, and trying once again to get a the display working. Again, make sure that the connection matches the source setting on yourmonitor. If it works on another PC, then your computer may have a videoproblem.
Otherwise, if it still does not work your monitor have a problem displaying viathat connection. If possible I would suggest switching to a differenttype of cable and re-try the above steps.
AOC FOVI F19S... | Answered on Mar 20, 2011
There is a fault with its power cable or power plug inside and it may power button is not working properly.
Best of Luck
AOC FOVI F19S... | Answered on Mar 07, 2011
You need to use Fn keys and F4, 5, 6, or 7 depends on the brand of the PC to select the internal/external/ both display. You will alo need to set the windows diplay properties to set the external to be duplicate, extended desk top, etc.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
AOC FOVI F19S... | Answered on Jan 31, 2011
Please try here: http://www.fixya.com/support/r4628438-aoc_monitor_lock_unlock_instructions
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series
AOC FOVI F19S... | Answered on Jan 28, 2011
How to remove OSD lock from View sonic monitor
AOC FOVI F19S... | Answered on Jan 17, 2011
Please try this:
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
If it is just the OSD in the menu, try the reset function. The "R" symbol in menu is for reset.
AOC FOVI F19S... | Answered on Jul 21, 2010
Only the owner will know that.
AOC Computers &... | Answered on Jul 07, 2019
I am in need of this model software
AOC Computers &... | Answered on May 01, 2019
I have dual AOC i2553ph monitors. One day I came into work and notice one of them had a single vertical white line moving slowly back and forth across the screen that looked like a scan or radar function. I reset the monitor from the OSD and all is well again. Use "Extra > reset" from the OSD on AOC monitors.
AOC Computers &... | Answered on Mar 25, 2019
Google (AOC)(21500032)(manual) without parens.
AOC Computers &... | Answered on Feb 14, 2019
Continue pressing the input select button on the monitor until you loop around to the input that you are using.
AOC Computers &... | Answered on Jan 08, 2019
AOC FOVI F19S Monitor Logo
18 questions posted
Top AOC Computers & Internet Experts
Ekse
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • AOC Computers & Internet
Most Popular Question
remove osd lock in aoc f19 monitor r n
  • Computers & Internet
