SOURCE: printer wont work!
get new printer drivers here first
install, then run a test page with printer disconnected from computer..
if that works, then reconnect printer to computer. should 'see' it, and proceed..
SOURCE: 52 scanner error
The printer has burned a scanner assembly. The part number is RM1-2033-030CN. The part is extremely expensive in relation to the printer cost. ($182.00 @ HP)
I would recommend surfing ebay for an HP Laserjet 1022 printer as it is the cheapest printer that has the same scanner. Even a dead 1022 will work as they tend to either have formatter or fuser issues when dead. A scanner error on your printer or the 1022 is extremely rare.
I have included a link to the HP 3050 service manual for you that will walk you through it step by step. The teardown is significant however very do-able by the novice with the service manual.
http://h20181.www2.hp.com/plmcontent/NACSC/Printers/LaserJet/30328_020806/course/library/service/service.html
Good luck, You can do it.
SOURCE: hp designjet 1050c printer displays a system error
Printhead failure this is.
Turn the printer on.
Following initialization,
use the Down Arrow key to scroll to the Ink system menu icon and press Enter.
NOTE:If the error code appears during initialization press the Enter
key to allow printer to complete the rest of the initialization process.
Scroll to Replace Printheads and press Enter.
The printer should now move the carriage to an accessible position.
Open the top cover.
Remove all four printheads.
Turn the printer off using the main power switch located on the back of the printer.
Following initialization, insert one printhead at a time, starting with the black printhead.
Determine whether or not the printer accepts the printhead.
Turn the printer off and repeat steps for each of the printhead.
Replace the failed printhead.
Hope this helps
Regards
SOURCE: hp color laserjet 2600n displays error 55.1 turn off then on
hello friend i have a printer HPColor Laserjet 2600n it displays Erroe 55.1 Turn OFF/ON. How do i over come this problem?thx
SOURCE: My M2727nf doesn't coppy or
Hi this is def a hardware failure:
Try doing a nvram
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work, have it serviced they will need to replace the formatter board as well as the scanner assembly.
If within 2 years from the purchase date contact HP and request for a case number the printer has a service note for a scanner error 5 or 8.
Al
[email protected]
Thank you for contacting Fixya.com.
AF is an error that will flash if a restricted air flow is sensed by the dryer control. If three consecutive cycles have low airflow the control will flash the AF error.
The AF error code can be cleared by pressing the Drying Temp pad for 5 seconds while in stand-by mode. AF will flash in the display for 1 second then "on" will appear in the display. If you press Drying Temp again and "of" will appear in the display indicating the AF error display has been turned off. Try this procedure and see if the "of" error goes away. If the "of" came up in the display by itself then the keypad may be stuck. However After cleaning the dryer's lint screen, ensure that the exterior exhaust hood connected to the dryer is unblocked, ensure that the vent connecting the dryer to the wall is clear and see that the vent is cleaned professionally.
Please get back to us if you have any further query.
