Question about HP Laserjet M2727nf Multifunction Printer
My M2727nf doesn't coppy or scan. message displays " error 5 Turn off and turn on." After turning off and on, it keeps displaying the same message.
Posted by quaziiqbal on
aswini
    New Friend:
Dear sir,
My Name is Aswini for chennai
i have i doubht for Scanner error 8 turn off than on
make hp laser jet M2727 nf
Posted on Mar 16, 2015
Al Toledo
  • 223 Answers
Hi this is def a hardware failure:
Try doing a nvram
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work, have it serviced they will need to replace the formatter board as well as the scanner assembly.
If within 2 years from the purchase date contact HP and request for a case number the printer has a service note for a scanner error 5 or 8.
Al
[email protected]
Posted on Jul 14, 2010
79 error turn of and turn on
Try doing an NvRam on the printer (Hard Reset):
2. Press and hold the right arrow and the cancel button
3. Turn the printer on while still holding those buttons
4. Keep holding them until you see a message that say "permanent storage init"
This should clear that error message
Aug 05, 2010 | HP Laserjet M2727nf Multifunction Printer
Error 5 hp n2727nf
This is due to a formatter failure, and the scanner assembly and the formatter board will have to be replaced.
Try an nvram
if this does not work contact hp, if within 2 years from the purchase date ask for a case number to have the printer serviced under a service note.
Al
Aug 02, 2010 | HP Laserjet M2727nf Multifunction Printer
HP m2727nf scanner error 5
Hi Anataloi,
This is due to a hardware failure, the scanner assembly and the formatter board will need to be replaced.
if this does not work contact hp 1800-334-5144 , if within 2 years from the purchase date ask for a case number to have the printer serviced under a service note.
Al
[email protected]
Jun 25, 2010 | HP Laserjet M2727nf Multifunction Printer
I have Networked hp model M2727nf all-in-one printer/scanner/fax.displies error "scanner error 5" on the display screen. i turned off/on the machine more than 4 or 5 times the error does not go away!
This is due to a formatter failure.
Try an nvram
Al
[email protected]
Jun 15, 2010 | HP LaserJet 2840 All-In-One Printer
After I turn it on it shows an error messaje
there are problem in scanner assembly. please clean care fully and properly of your scaner unit.,than its ok.,
May 10, 2010 | HP Laserjet M2727nf Multifunction Printer
Our hp lj doesn't work anymore. After restart it says "Scan Error 5" or "Scan error8". This morning I managed to send a last fax but after this it stopped working. We had problems with printing those last...
this printer is experiencing what is known as a formatter/scanner assembly failure, hp has a service note issued to service printer up to 2 years after the purchase date.
if this does not work contact hp. 1800-334-5144 in order for them to create a case under the service note and have the printer serviced. Both the scanner assembly and formatter board need to be replaced.
Al
[email protected]
Mar 24, 2010 | HP Laserjet M2727nf Multifunction Printer
Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
Feb 23, 2010 | HP Laserjet M2727nf Multifunction Printer
I've got a new hp m2727nf laserjet (3 weeks old), and an error message "ADF door is open" appears in the product display. I have turned off and unplugged the power several times, I've removed the adf and...
From HP's web-site:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=3377075&prodTypeId=18972&prodSeriesId=3377075&objectID=c01236058
Make sure that the ADF lid is closed.
Remove the ADF and reinstall it.
If the message persists, turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the product to initialize.
If the error persists, contact HP. See www.hp.com/support/LJM2727 or the support flyer that came in the product box.
Dec 05, 2009 | Computers & Internet
Scanner error 5 turn off then on
Eva, This is a common problem with this machine and more than likely the scanner will need to be replaced. You should try calling HP and see if they will cover it since it is a common problem.
Nov 13, 2008 | HP Laserjet M2727nf Multifunction Printer
HP Laserjet M2727nf Multifunction Printer Logo
469 people viewed this question
Ekse
efs_perpends
efs_perpends
