SOURCE: Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
SOURCE: replacing a burner on a frigidaire electric stove
If you are talking about one of the four(4) elemnts on the top, all you need to do is pull it out and slide the new on back in. According to the model you provided, it has just the standard coil surface burners.
Good Luck!!
SOURCE: turn the stove on and hear a click but nothing heats up
If you don't want to spend the money for an entire board, I saw someone on ebay that sells just the relay. Its pretty simple to unsolder the old one and solder in the new one. Do a search for the part number on your relay which is probably T9AV5L12-12 and is notorious for going bad. I have not been able to find those relays anywhere else.
SOURCE: Frigidaire electric range model FEF379ACJ Does not work
You will need to replace the main control board/clock, on the unit. It controls everything on the unit. Here is the part to order.
