Question about Frigidaire Gallery GLEFM397DS Electric Kitchen Range
Turn the stove on and hear a click but nothing heats up
When i turn the stove on I hear a click and then nothing heats up or works. This is a Frigidaire electric stove model #FEF369HS
Posted by mark_hamm450 on
CajunOnStar
    New Friend:
  • 10 Answers
If you don't want to spend the money for an entire board, I saw someone on ebay that sells just the relay. Its pretty simple to unsolder the old one and solder in the new one. Do a search for the part number on your relay which is probably T9AV5L12-12 and is notorious for going bad. I have not been able to find those relays anywhere else.
Posted on Jan 09, 2012
Eric Duda
  • 999 Answers
The click is the relay so I would check the ignitor. If it is "open" replace it. If it "shorted" the valve is likely bad also.
Eric
Posted on Mar 26, 2010
Oven will not come on at all. I hear it clicking like its calling for heat but nothing. In regular baking or broiler. Stove top still works though.
the solder on the oven relay melts eventually.
if it doesn't ruin the board, you can re-solder it, otherwise you need a new control head.
Jun 15, 2011 | Frigidaire FEF365AS Electric Kitchen Range
Stove top or oven doesn't heats. range type is a accubake system
Have you check the outlet to see if its geting power, if not, check the main breaker in the breaker box, you may have to turn the breaker to the off postion and then back to the on postion, if power is going to the outlet your stove should work.
Feb 12, 2010 | Kitchen Ranges
Lower oven ignitor does not ignite
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
gsgs
Dec 24, 2009 | Maytag MGR6772 Gemini Gas Kitchen Range
Oven not heating
On the bottom is a link of what your oven is. I'm pretty sure it's the ingnightor #16. You should see a glow red hot when you turn on the oven or broil. Very common problem and pretty reasonable price to repair. Unless that glows and get's red hot, it will not turn on the gas. I think that should do it. Let me know if you need anything else. Scott
http://www.searspartsdirect.com/partsdirect/getModel!retrieveModelDetails.pd?modelNumber=SF325PEEQ0&productCategoryId=0124002&brandId=1198&modelName=Free-Standing,-Gas
Apr 19, 2009 | Kitchen Ranges
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Aug 31, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Gas stove works, but oven does not
you most likely have a bad oven ignitor...if you see an orange glow under the oven panel that is your ignitor trying to come on....but if it is weak it will not open the gas valve.....acess the ignitor and replace it
Jul 30, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
282 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Paul Carew
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
