RCA D52W23 52" HDTV CRT TV Logo
Posted on Jan 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power ligt blinks twice no high voltage
Rca model d52w19b flyback transformer was changed 2 years ago for arcing
Anonymous
Level 3:
  • RCA Master 5,138 Answers
  • Posted on Feb 13, 2009
Anonymous
RCA Master
Level 3:
Answers
5138
Questions
5
Helped
1004565
Points
13534
CK capacitors cp150 cp114 cp120 if cp150 is puffed up on top it is bad so replace all 3 caps.2200uf 16v and two 220uf 35v
The blinking of death.
set is trying to come on but not making it.
Most common issues with this model are bad connections around the high voltage transformer or on that same board.
A few will also have the High Voltage splitter at the very front of the set behind the front grill fail---a faint arc when you try to turn on.
8_30_2012_2_57_40_pm.jpgHigh voltage transformer
I have an RCA rear projection TV MOD: D52W19B SER: E315C30GD Chassis: ITC222. The flyback arcs when power is applied, several days ago the TV was operational, a loud pop emitted from TV, I unplugged it and...
yes it is a flyback transfomer is a very sensitive piece of equipment also known as a lot or lopt in you case i would say that the case has cracked on your flyback you may get by however if the damage inside is not significant yet be wrapping the flyback transformer in black electricians tape but this should not be a permanent solution
2helpful
Toshiba 32'' tv no power no sound red led in front on and blinks also hearing hissing from flyback model#cx32f60
for sure your tv has power as indicated by your flyback hissing it also indicates leaking high voltage that might destroyed your vertical or any other parts near your flyback ,the flyback itself should be replaced for its high voltage arcing can ruin so many components
3answers
RCA 52in. Projection TV D52W19B does anyone
Hello butmommy03,
This is the procedure but first I must warn you. You are dealing with one of the most dangerous parts of a TV The High Voltage anode or the CRT and the flyback transformer. That being said this is what you have to do:
1) unplug the TV from the wall or power strip.
2) take the back of the TV, and find the High voltage trippler and using a screwdriver grounded by a clip-lead to the grounding strip touch it to the exposed metal of the input to the High Voltage trippler.
3) using a soldering iron de-solder and remove the wire from the HV trippler.
4) Once this is done, angle the chassis to expose the bottom of the Deflection board, if this is no possible you will have to remove the deflection board to get a look at the bottom, once this is done and you can view the bottom of the board using a soldering iron and a de-soldering pump you can remove the solder from around the pins of the flyback transformer about 10 pins in all. Then remove the screws that hold the flyback in place. this is the procedure you requested,
However again I must ask you not to do this yourself and to get a qualified TV technician to troubleshoot this TV for you.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
My 52 inch rca tv has sound but the picture keeps popping on and off .what can be wrong with it?
2 THINGS THAT USUALLY CAUSE THIS PROBLEM IS
1) THERE IS AN ARC FROM ONE OF THE PICTURE TUBE ANODE LEADS--15.00-- THE TUBES ARE STILL GOOD , JUST THE LEAD IS BAD---NOT EASY TO REPLACE ,,YOU HAVE TO CUT THE OLD ONE OUT AND REPLACE USING SEALANT ....
2) A PART CALLLED A HIGH VOLTAGE BLOCK--75.00--THIS PART TAKES HV FROM A FLYBACK TRANSFORMER ,,,SPLITS THE VOLTAGE TO GO TO THE 3 PICTURE TUBES
KEEP IN MIND ,,IF YOU HEAR A POP--IT'S USUALLY A HIGH VOLTAGE ARCING TO SOME METAL--YOU ARE BETTER NOT PLAYING THE TV
THESE JOBS ARE BEST DONE BY TECH'S -TUNICA
Rca arcing and hissing
Most likely,you have a bad transformer AKA flyback ......
Is 32V420TYX6 the service # of your TV ?......Verify..........T.
1helpful
3answers
Rca d52w19
You can change the HV splitter first,then change the flyback
transformer, if necessary.......Do be careful with part number
of transformer....check the drawing number on it ......10756 =
259296.......10799 = 265409......as examples..........
I can check on that for you based on your info................T.
2answers
RCA 52 inch tv will not come on and has no sound
Right now i have two of theses sets in my shop and what i am finding out is they have big problems with bad flybacks and high voltage tripplers.both of these set have now shut down and will not come back on so how much is all these parts ,will post that when i find out!
RCA 35V432T Dead Set
Check for a high voltage power supply section of your TV set...
Especially in flyback transformer.Be careful to do so because the output voltage of the flyback transformer is almost thousand volts.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
