volume keeps cutting down. Have to use remote for the cable. It will not cut volume back up but if i...
(More)
volume keeps cutting down. Have to use remote for the cable. It will not cut volume back up but if i keep pressing the up on the remote, a message comes up on the screen about warranty date and hours. I have no idea how to stop this. If i go to menu, the volume stays up until I close menu, then it goes right back down. I can only cut it up with the volume control button on the front of the tv.
No sound when connected to cable. No sound when disconnected from cable and the audio output cable...
(More)
No sound when connected to cable. No sound when disconnected from cable and the audio output cable is removed. (No static or cracking noise from speakers, zip.) Sound when connected to DVR player, and the sound IS coming from the speakers.
My 35 inch Tv does some quite random things. For instance it will turn of or on at will within...
(More)
My 35 inch Tv does some quite random things. For instance it will turn of or on at will within seconds of each other. Secondly, there are times when you are trying to turn the volume up or down, and it changes "input", and will not turn off or on without the remote. When it does that the buttons on the tv are non-responsive.
I dropped my unit and now the bottom half show things purple (cool colors). Otherwise the unit still...
(More)
I dropped my unit and now the bottom half show things purple (cool colors). Otherwise the unit still works perfectly. Is the problem anything that I can fix myself?
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
On Feb 18, US viewers with analog TVs will no longer receive free over-the-air programming. In other words, if you've got an older TV with rabbit ear...
written by Lauren_FixYa
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method...
written by techman
Update
A number of people have commented that after changing the color wheel,
their red and blue colors are reversed. This is a different color...
written by sweet_rascal
7. Locate the color wheel cover. It?s got a small green circuit
board on top of it with a black/blue wires connected to it. Remove that
plug. Also,...
My television is model Samsung HLM4365WX and the color wheel part
number for that is BP96-00250A. This color wheel is used in many, many
Samsung...
I?ve got one of the early models of the Samsung 43′ DLP Television
sets. We?ve been through a lot together, but it?s just a...
Don't put up with your faulty buttons on you Remote Control anymore! If some of the keys on your remote have stopped working or you have to push...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
