RCA 32V420T 32" TV
Problems with RCA 32V420T 32" TV?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
RCA 32V420T 32" TV
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for RCA 32V420T 32" TV RSS Feed
Click here to get instant support from our best Experts!
View More Results for RCA 32V420T 32" TV
Questions and Unsolved Support Problems
Unsolved Problems for RCA 32V420T 32" TV RSS Feed
Answer
My TV recently started to turn itself on and scan through the channels. It is the TV channels not... (More)
Answer
my tv will not turn on anymore it only flashes the red light for about 30 seconds and then stays... (More)
Answer
Dark blue screen channel will not go up and down it's on but it seems stuck . Remote will function... (More)
Answer
Dark blue screen is stuck. channel will not go up and down. remote control will only do menu volumn... (More)
Answer
I have an older model Mitsubishi, it is one of the huge 40 inch TUBE tv's. The picture is great once... (More)
Answer
According to my technician, the transformer had to be replaced. I'm not sure what a new one costs,... (More)
Answer
I have the RCA 32V434T model and last fall (less than a year old) mine did exactly what all of you... (More)
Find a Manual
RCA 32V420T 32" TV Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
My Magnavox TV is showing a feature screen
Press the channel up and volume down buttons at the same time on the front of the tv until the set goes off. When you turn the set back on the feature... written by rusty_etech
Magnetized TV, Poor picture, blotches, discolored, target shaped image
If your set looks like the one pictured above it is likely magnetized and needs to be degaussed (or demagnetizing). All CRT type TV's are prone to... written by johnnydiode
Help FixYa, Help you and help others. Share your User maunals and...
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for... written by stoneheaded
DTV transition: Options for Those with Analog TVs
On Feb 18, US viewers with analog TVs will no longer receive free over-the-air programming. In other words, if you've got an older TV with rabbit ear... written by Lauren_FixYa
Removing parental lock on RCA and GE TV sets
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method... written by techman
repair job update
Update A number of people have commented that after changing the color wheel, their red and blue colors are reversed. This is a different color... written by sweet_rascal
repair job continued
7. Locate the color wheel cover. It?s got a small green circuit board on top of it with a black/blue wires connected to it. Remove that plug. Also,... written by sweet_rascal
Purchase a Color Wheel & The Repair Job
My television is model Samsung HLM4365WX and the color wheel part number for that is BP96-00250A. This color wheel is used in many, many Samsung... written by sweet_rascal
WikiManual
(Post a New Chapter)
How to Repair a Remote Control
Don't put up with your faulty buttons on you Remote Control anymore! If some of the keys on your remote have stopped working or you have to push... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for RCA 32V420T 32" TV
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Ratings for the RCA 32V420T 32" TV
RCA 32V420T 32" TV
0
Owners Recommend
out of 1
Reliability
Ease of use
Value for Money
Rate and Review the RCA 32V420T 32" TV
Write a review:
Rate this product:
Would you recommend the 32V420T 32" TV to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for RCA 32V420T 32" TV
Key Features
Screen Type
Non-Flat Screen
Diagonal Screen Size
32 inch
Digital TV Standard
Analog TV
Display Capabilities
Aspect Ratio
4:3
Built-in Tuner
NTSC
Image Quality
Velocity Scan Modulation
Without VSM
Comb Filter
3DYC / 3D Digital
Adjustable Color Temp.
With Adjustable Color Temperature
Audio Features
Audio Output
Fixed
Audio Type
Stereo
Sound Leveler
With Audio Leveler
SAP / MTS Stereo
SAP / MTS Stereo
Technical Features
Picture in Picture
Without PIP
Sleep Timer
With Sleep Timer
Connectors
Front Input Connectors
S-Video x 1
Screen Text
OSD Languages
English · French · Spanish
Channel Labels
Without Channel Labels
Dimensions
Depth
22.5 in.
Height
29 in.
Width
30.1 in.
Weight
120 lb.
RCA Contact Information
Main support number580-634-0151
Describe your problem:
Top Standard... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
