HP DeskJet 930c InkJet Printer Logo
Posted on Jan 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP Deskjet 930C USB connection
Is it possible to connect an HP deskjet 930C printer using a USB cable rather than the 'old' style printer cable. If so could you advise which cable I would need to purchase as I presume that the port on the printer would need a special type of connector.
Thank you
Anonymous
Level 2:
President:
  • Expert 8,637 Answers
  • Posted on Jan 23, 2009
Anonymous
Expert
Level 2:
President:
Answers
8637
Questions
0
Helped
2741054
Points
514
Yes but you may have to re-install the software for the camera. If so,
Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Can i use my nextbook tablet with my hp deskjet 2600 printer
HP Deskjet 2600 Printer USB Setup is one of the easiest methods to connect the printer and system. This procedure is compatible with both Windows and Mac operating systems. Follow the steps below to start the connection process.
123 HP Deskjet 2600 USB Setup
HP 2600 USB Setup for Windows
STEP 1: BEFORE PRINTER SETUP
  • Examine if the printer is turned on and is in a ready state. Check if the USB cable is present in the printer's shipment box.
  • Connect one end of the cable to the printer's USB port and the other end to the system's port. Do not connect the cable during driver installation.
  • Wait till the printer's name displays on the list of available devices. Select the name to start the process. If the name is not displayed, move to the next step.
STEP 2: INSTALL THE DRIVER
  • If the driver is not installed in the system, the issue occurs. In such cases, try to download and install the driver.
  • Locate the compatible driver for your printer model on this website. Select the best driver and then click the Download option.
  • After completing the 123 HP Deskjet 2600 Setup driver process, follow the instructions mentioned on the screen. Select the connection type as USB.
  • Choose the Custom option to avoid the download of unnecessary downloads and click Finish to complete the process. for more Visit https://goo.gl/KoXrvJ
tip
EZ steps to install HP printer in Windows 7 without Installation software
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers. The Devices and Printers window opens.
  3. Click Add a printer. The Add Printer window opens.
  4. Click Add a local printer.
  5. Click Use an existing port.
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port), and then click Next.
  7. Under Manufacturer in the Install the printer driver window, click HP.
  8. Under Printers, select approriate drive from below list provided and then click Next.
  9. In the message window, click Finished.
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. Click Close to close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties. The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  15. Click OK.
  16. In the Properties dialog box, click the General tab.
  17. Click Print Test Page.
Determine the appropriate compatible driver
Deskjet 3320, 3325, 3420 and 3520 -------------Deskjet 3600 *
Photosmart 7600 series------------------------------ Deskjet 5600
Deskjet 5850 ---------------------------------------------Deskjet 5600
Photosmart 130, 145, 230 and 245 ---------------Photosmart 330 *
Photosmart 7350 and 7550 --------------------------Deskjet 5550
Deskjet 6122 and 6127 --------------------------------Deskjet 990c *
Deskjet 3820 -----------------------------------------------Deskjet 970cse *
Deskjet 656 ------------------------------------------------Deskjet 660c *
Business Inkjet 1100d ---------------------------------Business Inkjet 1000
Business Inkjet 1100dtn ------------------------------Business Inkjet 1000
Deskjet 9300 ----------------------------------------------Deskjet 1220c *
Deskjet 9650, 9670, 9680, 9680gp---------------- Deskjet 9800
* Available only through Windows Update.
(Happy Printing)
Regards
Rizwan
How can I make my HP 930c print with no color cartridge?
you cannot make it print with no cart, but if you have an old one, drill holes in the top and fill with water, 930c uses weight to establish ink level, after much mucking around I have done this today, printing right now :)
I bought another deskjet 932c from e-bay to replace my old one. I have windows 98se which is not connected to the internet. When plugging in the 932c I just bought, a message comes stating that there is...
Try a self test disconnected from the computer by pressing the 2 left buttons for 4 seconds and then wait for about 15 seconds for a test page to begin. Some models were the right 2 buttons pressed for 4 seconds. If it self test ok then it is software or cable interface. Make sure you are using the same USB or parallel port as before or reset the printer properties to that port. Sometimes the printer dip switches have been messed with and your system will not see the printer properly.
My computer does not detect the printer when I connect the USB cable
for this
please check teh usb port
by doing right clcik on my computer icon - then properties- hardware - device manager - under universal bus controller - check if you have any red cross if its teher then rigfht clickon tht and enable it
If not then do a right clcikon usb and click on uninstall and then do a rigfht clcukon universal bus controller and clcikon scan for harwasdr changes and make sure that the printer is connected
I have a HP deskjet 930C that has been connected to a desk top. I now have a lap top and need to know how to connect it. I Do not have the disk the printer came with. I know this printer is older but...
Hi:
The deskjet 930c will hook up to your laptop with a USB printer cable, no problem.
If you hook it up to your laptop, and turn it on, Windows should have the driver built right in. If not, you can download the driver from www.hp.com from their support/drivers link.
I cannot get my HP deskjet 932C installed again. I disconnected it to have my computer repaired. I did unstall and re-install the software, but am still getting the same message that it cannot find LPT1....
To begin with, here is a link for the user guide for your printer:
HP 930C User guide (Even though it says 930, your 932 should be nearly identical.)
Page 40 begins the setup instructions. If you are going to use the parallel printer cable, the printer port must be enabled in your BIOS. What did you have "repaired"?
It would be easier to get a USB cable and connect it with it, that is if you have a USB connection.
What operating system are you using? That may help me understand your problem better.
1helpful
3answers
2answers
Installing issues
Download the updated drivers from the HP site.
k24674
Grand Canyon Tech
Grand Canyon Tech
