Hi there, I believe the elements in your steamer are replaceable, I would check the supplier, or eBay, just have your make and model at hand,
I hope this helps
see this causes and fix it. God bless you If the vacuum cleaner motor doesn't run the on - off switch might be
turned off or defective. Test the switch with an Ohm meter or continuity
checker.
If the vacuum cleaner motor does not run the motor itself might be
burned out. Check the power switch first to be sure the motor can get
power. Then, be sure the motor shaft can turn freely, that nothing is
obstructing it. If the motor can turn freely and is getting power but
still won't run it will need to be replaced.
There is a heat sensitive switch attached to the inner pot. It is very small, it turns the heat off when the pot reaches boiling temp. If it is open, replace it. They come in different temps, so get the right one. This one is supposed to open at 212 degrees, f. You will find a similar one in a Mr. Coffee, it switches the pot from boil to keep.
it has a tiny themo circuit in with the winding of heating element most heater made in china cheap so be looking for a contact piece like points on your old distributor on your car ...check if Ni-chrome element did not break somewhere can be fixed ...if you are check in the states harbor freight has some as well bout $ 29.00
