It has a tiny themo circuit in with the winding of heating element most heater made in china cheap so be looking for a contact piece like points on your old distributor on your car ...check if Ni-chrome element did not break somewhere can be fixed ...if you are check in the states harbor freight has some as well bout $ 29.00
SOURCE: I have a wagner 404
It sounds like one of two things...
either the pump seals need replaced or the motor is not running fast enough under load.
Check for loose wiring on the motor, the brush holders and condition, and make sure that the air path to cool the motor is clean and free of obstructions.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
SOURCE: After about 6 days of
Check the wiring connector you are un-plugging to make sure of the internal connection.
