Televison & Video Logo
alyssa Posted on Dec 01, 2012
The black on the edges are always there but never used to be even on widescreen how do u get the full picture
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Dec 01, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
99
Points
6
Look for a FORMAT button on your remote or format option in the TV menu.
1 Related Answer
snakehead
Henry Thomas
  • 1074 Answers
  • Posted on Mar 26, 2007
SOURCE: iLo-26HD Tv
take your set to a tech you are having problem in your vertical output circuit.leaky filter or coupling capacitor,or defective B+ regulator transistor or IC .buffer transistor or IC,or supply resistor, they need to be replace.good luck
1helpful
SHARP AQUOS 46INCH CANT GET A FULL PICTURE ONLY IF I USE ZOOM WILL THE SCREENBE FULL
Hi Anthony,
You're describing what is called letterbox and pillerbox. Letterboxing is when there are two horizontal bars - one at the top and one at the bottom of the screen with a wide picture between. Pillerbox is when there are two vertical bars - one on the left edge and one on the right edge of the screen with a tall picture between.
The settings on your TV (and on your cable box, satellite box, DVD player, etc.) tell the TV how to display a picture that will not fill the screen completely. If the program source (an older video-taped TV show, non-widescreen version DVD, etc) was not originally "shot" or saved in widescreen format, the TV offers you a choice on how to display the image. They ask if they should stretch or zoom to fill the screen (and you have to deal with the skinny / tall images or lost portions of the picture); or maintain the aspect ratio (not stretching or zooming) by leaving a part of the screen blank (grey or black) by inserting bars left and right or top and bottom of the screen.
Start out by telling the devices that send pictures in a format that matches you TV's screen ratio. I am assuming you've got a wide screen HDTV which would mean it should be set to "16 x 9" (a.k.a. 16:9) ratio display. If you have it set for 4 x 3 (a.k.a. 4:3) you should change it. Look for a setting on your TV that asks about stretching, zooming, etc. as this will be an issue when receiving picture from an off air antenna on your house when a TV station is airing an older, non-wide screen format TV show or movie.
TV signals provided by Cable TV or Satellite provider must be HDTV type signals. If you have the standard TV service (non-HD) no picture sent by them will ever fill the screen. This is because Standard Definition TV (SDTV) is not capable of those types of signals. You will have to bump up your subscription to HDTV service to get full screen pictures.
I hope this helps!
I am having trouble getting the screen size back to full size. We used the zoom but that makes the picture to big. My TV is a Auria EQ5588
Hi, The " Size " of a flat panel tv ( when not in zoom mode ) is actually controlled by your programming, if using an hdmi cable from an Hd/Blu-ray player-then whatever format the disc was recorded in is what you'll see ( widescreen/letterbox ) black bars at top & bottom of scrteen ) or full screen. Local over the air digital H.D. brodcast's from networks varie from full screen to letterbox-satellite and cable that are standard definition will almost always letterbox a screen for you. Using T.V.s tuner may alleviate most of the issues. Good luck and I hope this helped. Prodzilla
How do i get my olympus sp800uz to full sceen
If I understand your question right, you want to see your made pictures at full screen without black areas. Well, if you have a widescreen monitor, you can set the camera to take images in widescreen 16:9 format. Thera are menu settings: 16:9 L (4288x2416) and 16:9 S (1920x1080) or crop your pictures with a dedicated graphic tool program.
The picture is crunched like if you were watching a letterbox movie.(with the black at the top an bottom of the screen how do i correct this
Black on top of bottom is widescreen.. Some dvd's are made in only widescreen. Usually you have to buy a full screen disc to cover the entire screen or change to format to 16:9 or 6:9 or whatever it handles/
You may see the black on top and bottom, it is annoying at first, but the picture is so much wider and you can actually see more on a widescreen
1helpful
2answers
Black Bars on all blu ray movies
Hi icmjrtdr,
Having black bars displayed when watching a Blu-Ray disc is a common occurrence, even with a widescreen television.
You may have heard or seen aspect ratios of 4:3 or 16:9. 4:3 is the ratio of a traditional television that is nearly square. 16:9 is the ratio of most widescreen televisions currently marketed. The reason that even with a 16:9 television Blu-Ray discs are displaying black bars is that many of these discs contain footage that has not been reformatted for television. The screen in a movie theater is even wider than 16:9, and rather than trim the ends, most Blu-Ray discs maintain the entire picture.
Depending on the options available in your particular television, you may be able to find a zoom setting that trims the ends and removes the black bars. It is up to you if you would rather see black bars with the entire picture or lose a small amount of the picture on each side for a full-screen experience.
Hope this helps,
Jason,
Go Ahead. Use Us.
1}DVDR 3480 playback on many Dvds widescreen insteadof 4.3 as set. 2) my Vcr. has 3pin phono. Dvdr scart to Phono .Xt2 says nosignal. Phono tophono (cam socket) no signal .cannot copt tape to DVD. 3)B W...
1) The 4:3 / 16:9 option only optimises playback for that particular type of TV. The 4:3 setting also allows you to set the output between:
  • 4:3 PS - expands the picture vertically and horizontally which gets rid of the black bars, but you also lose the left and right edges of the picture.
  • 4:3 LB - Letterbox format, displays the full picture from the disc, with black bars top and bottom.
The PS option loses the bars on 16:9 widescreen DVDs, but may still leave bars on true cinema widescreen DVDs, which are 21.7:9
This is normal.
  • 16:9 - Optimises the picture for a widescreen TV. Again True cinema widescreen DVDs will still have black bars.
2) All of the external inputs will show "No signal" until there is actually a signal playing into them.
EG to copy VHS to DVD, you will need to select the relevant scart or phono input, and press play before the recorder will register a signal and allow recording.
Some bought VHS videos have copy protection, and may cause problems when copying to DVD.
3) Greenish playback maybe caused by colour setting on TV being too high. Also check Hue or Tint settings on the TV, if it has them.
4) For some reason, in their infinite wisdom, Philips omitted the Video Plus facility from this model.
Widescreen cinema mode
Make sure the DVD player is set to 16:9 screen mode.
If you still get the bars at the top & bottom, then its probably because the DVD was filmed in true cinema widescreen, (21.7:9) whereas the TV is only 16:9.
There may be other settings on the DVD player to expnad the picture out, but you will either lose the edges of the picture, or it will be stretched.
Widescreen
Unfortunately, a cinema screen is even wider than a widescreen TV. Because of this (in order to keep the original aspect ratio), even with a widescreen TV you still end up with the black bars top and bottom.
Check the aspect ratio of the DVD (Should be printed on the back of the case somewhere).
Unless it says 1.85:1 or 16:9 Anamorphic, you will get the black bars. (Many films on DVD are 2.35:1 or even wider!)
Have you got any different picture modes on your TV. I've got a Toshiba and it has something called 'cinema mode' which does eliminate the bars. Unfortunately it does it by zooming in on the picture slightly, so you loose a bit off the side of the picture and the image does get a little grainier.
Hope this helps.
Matt
2answers
No full widescreen on HD broadcasts
Do you know what the aspect and resolutiuon settings of the cable box are? What brand of cable box is it?
ILo-26HD Tv
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
