I have the 3.0 v6 is ther a trick to changing the fuel filter cant seem to get the front line loose from filter not enough room to get a wrench on it at all please help??????????
The fuel filter is under pressure so be sure to remove the gas cap before attempting to remove the filter. If not you will strip out the nuts. Run your vehicle until the reserve fuel light has been on for 20 or so miles. This way you can let the remaining fuel (1-2 gallons) run into a gas can and you can reuse it. Unscrew the nuts from the gas tank side and the engine side, then install the new filter. The fuel filter is located on the passenger side, almost directly under the front seat, but on the undercarriage. Hope this helps.
