LG WD-1280FHD Front Load Washer Logo
Posted on Jan 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LG Wash-Dry WD14700RD pump or solenoid noise
While pump operating a heavy electrical overload noise /vibrating while pump operating, problem not constant, sometimes works quietly, on one occasion rattly noise.
Anonymous
Level 2:
Sniper:
  • Expert 88 Answers
  • Posted on Jan 11, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
88
Questions
Helped
61514
Points
231
This is indicative of a bad impeller in the drain pump motor, it will most likely need replaced.
Make sure you check the drain filter for any loose coins or articles that may have been trapped and hitting against the drain pump impeller. If it is clear then the motor is indeed bad. Hope this helps, please rate my solution.
2answers
My lg washer is making a loud noise at the end of the wash cycle.
When you do hear your LG washing machine making a loud banging type of noise on the spin cycle it could be caused by overloading or a loud that is unbalanced Or the bearing has worn out and needs replacement.
Hi, I have a Kenmore quietquard dishwasher model number 587.14012406a and it's making a loud noise throughout the wash it then stops and then restarts which is a vibrating noise and is extremely loud!
suggestion, i suspect you have got something in the wash pump or the pump impeller is breaking up this can cause a vibrating noise or it could be the rince pump.
Fan is noisy intermittently well after wash is finished
It depends on what model you have. The fan is usually operating when the dry cycle is on. The dry cycle can be quite long compared to the actual wash (which ends when the rinse water is drained out). The dry cycle uses the steam in the dishwasher to circulate around the dishes. The fan keeps running until the full cycle is complete. If you are hearing heavy noises when the fan is running, then the bearing of the fan maybe damaged and you need to replace the fan.
Hobart LXiH error E4 AND part makes noise when OFF
test this steps and fix it. GOd bless you
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
5helpful
LG DLE 2514W DRYER MAKES RUMBLING NOISE WHILE RUNNING
Hi Willie Bolden
Sounds like your problem is drum rollers are in need of lubrication or replacement.
Go to the following webpage for a schematic of your dryer and parts.
Please take time to rate me
Bud
http://www.appliancepartspros.com/parts-for-lg-dle2514w-abweeus.html
Sudden loud vibration from the door of my Whirlpool dishwasher. Replacing the part didn't help.
see this causes and fix it. God bless you
Drain Pump If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Circulation Pump If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Experiencing extreme vibration and noise with my LG WM2101H...sounds like a rocket is taking off everytime i wash something...it's on a pedestal, overflow pan and is located on the second floor...no...
This is actually pretty normal for newer LG front loaders. They've done a lot of work to isolate the vibration and noise from the spin cycle, but the higher RPM's have countered those improvements. Unless the manufacturer/technician can determine that something is actually wrong, you're probably going to need to install an anti-vibration pad under the washer pedistal to absorb most of the noise. It is very likely that the subfloor is actually amplifying the vibration into the "rocket" noise that you are hearing. Try installing Silent Feet anti-vibration pads or similar to prevent this amplification of the noise and vibration.
2helpful
Vibration during spin cycle
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Buzzing noise! when the
sounds like you have a problem with the water solenoids (the electronic controlled water valves) the buzzing is an indication that it is trying to open or close and unable to do so. an electric current creates a magnetic field pulling a spring loaded valve sealed inside a tube allowing water to pass. it starts buzzing when it can't pull the valve all the way and just vibrates.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
