These dishwashers have a control panel lock feature that allows you to lock the control panel to prevent kids from activating the unit.
To toggle lock/unlock mode, open the door, press and hold the AIR DRY button for 4 seconds.
Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Hi, Whirlpool makes their control lock very confusing. Often times, people will look on the control panel and the control lock light will go on and they can not figure out how to unlock the control panel. They will try pressing and holding the cancel button and unplugging the washer or dryer to reset it. None of these options work. All you need to do is press and hold the end of cycle button for 3 seconds and the control panel will unlock. If that doesn't unlock your controls, then unfortunately your interface control board is just shorted and will need to be ordered and replaced to fix the issue.
Press any of the buttons on the control panel to see if the buttons are
operational or check to see if the "Control Locked" indicator light is
lit. If the control panel is operational, you may mistakenly lock the
door.
Press and hold the "End of Cycle Signal" button for approximately three
seconds until the "Control Locked" indicator light shuts off.
Try pressing an holding the "End of Cycle Signal" button on the front panel in for 3 seconds. This button is used to lock/unlock the control panel to keep small children from manipulating the controls when the dryer is not in use. A designed safety feature. If this does not work for you, please post back and let me know. I hope this helps you.
take a good look and read on your control panel i don't remember which button you need to hold for 3 or 5 second to lock unlock control panel. it is also called child lock system.
bottom button on last row on right side of control panel depress and hold for 3 seconds it should activate or deactivate control lock if this does not help you could have a faulty control panel
In my case, the problem was a dead main board. The board cost $190 and the overall repair cost $335. I will never buy another Whirlpool due to this experience.
