You should not go to service mode for convergence adjustment IF convergence data has not been changed / tempered as yet.
I think TV was working fine until above said parts blown out. You replaced but problem still exist. This means there is still few parts in convergence section need your attention and to be tested.
Adjustment Procedure (Normal Mode)
1. Input an NTSC signal.
2. Press the Service Only switch on the Convergence board to enter the
Digital Convergence Adjustment Mode (DCAM).
3. Place the remote control transmitter into the Digital Convergence
Adjustment (DCA) Mode by removing a battery, pressing and holding the 7 and
9 keys, and replacing the battery.
Display Remote Control Diagram
Note: When the remote control transmitter is in DCAM, the TV button will not
illuminate.
Note: The remote control transmitter will time out of DCAM in approximately
20 seconds.
4. Press the Help key on the remote control transmitter. A green crosshatch
will appear.
5. Press the Exit key (this is the Phase Adjustment Mode).
6. Adjust the data value using the keys specified in the chart below so that
the data value corresponds to the chart value.
Saving Data Values
7. Press the Help key to exit Phase Mode.
8. Press the PIP (-) key twice to store the information.
9. When green dots are displayed, press the Mute key.
You need to download a service manual for your tv.. check techlore.com or servicemanuals.com - the service manual will tell you everything you need to know to get your TV into service mode, Also It will have complete instructions on how to set the coarse convergence and fine convergence - after this, you will be able to save the data so the intellisense mode will set the tv back to how YOU set the convergence. Good luck, and let me know if you have more questions.
Robshow has posted a link to the service manual.. also, I forgot to add, If you replaced the Convergence IC's, make sure you bought new SANYO IC's - there are TONS of cheapie counterfiet chineese IC's on ebay for 5.00 --- Â these IC's are very unpredictable, they may last 3 years, they may burn up in 3 minutes. If you used cheap IC's then they could also be the reason you couldnt get the convergence lined back up correctly.
Nevermind, the manual Robshow attached is the Owners manual, you need the SERVICE manual.
They have the service manual available for immediate download at manualuniverse.com for 17.99
Just select Phillips/Magnavox and type in the model number, 55PP9401.
I have attached the manual for the Tv in case you didn't have it. Let me know if you haven't fixed your tv yet. Click on the link below for PDF
Manual
Reset your tv with defaults settings.f chip and resstor blown then it need change.
Ok press the ----F (functions)-- key and --- MENU--- key together on the remote and keep it pressed for 5 seconds .pointing towards tv which will let you go in maintanence mode.
thanks.
How do i reset the tv settings
Again I turn off then do the settings but how
