You need to replace the clutch assembly. Here is the kit to order.
Below is a video to show you how to make the repair.
SOURCE: washing drum will not agitate
Dear Sir/madam,
First check the Lid switch, motor and belts.
With all that you check, this would be the next thought, this is rightunder the tub AGITATOR, Remove the LOCK SCREW and you should see it.
http://www.partselect.com/xq/aspx/Inventory.65335/qx/PartDetail.htm?SourceCode=1
Parts break down
http://www.partselect.com/ModelFrames.aspx?ModelID=103581&ModelNum=LAT8234AAE&mfgModelNum=&ManufactureID=1&Selected=35576&Position=6&mfg=Maytag&Type=&Mark=6
thanks
good luck
SOURCE: washing machine high speed spin
yea thats ok, just replacd 2 this week for same issue, theres a few monitoring switches within the latch assy, that dont allow it to acheive high speed spin withiout closing,I would definalty go to this before the timer
SOURCE: Kenmore mod. #417.44092500 high speed spin doesn't
replace speed control board located right rear base of unit
I jumpered out the door switch to eliminate this possiblity
