Whirlpool type 107
I have a used Estate by Whirlpool Heavy Duty Extra Large Capacity washer that fills up great and agitates great in the washing cycles, but I have to run it through the spin cycle several times because on the initial times it wont wring the clothes out. It appears to drain most of the water but the clothes are still dripping wet on the initial spin. Once I run it through a second spin cycle it wrings them out great. Also, I just noticed a smell of burnt rubber. Machine info: Type 107 TAWX700PQ0 Ser CR4219531 SM 8525147-A (some # on the lid)
Posted by Kentucky Rain on
Irwin Appliance Service
  • 3 Answers
Sounds like the clutch may be slipping. Does it go into a high speed spin?
Posted on Oct 20, 2014
4 Related Answers
Anonymous
  • 221 Answers
SOURCE: 10yr whirlpool toploader wash machine no spin/agitat. but works?
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on Jan 08, 2009
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: Washer not spinning/agitat
This problem is usually attributed to a broken motor coupling. The following link provides step-by-step instructions on how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is a small 3-piece component that is installed behind the drive motor and couples it to the transmission. It is common for these small couplers to break as they wear out. The key symptom in determining the cause is the fact the washer will not agitate, but still drains. The reason is because your drain pump is mounted on the front of the drive motor and will still run as long as the drive motor is running. The part number is provided in the link I gave you. A replacement coupler can be purchased at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com or repairclinic.com. All these sites offer great service with competitive pricing, so shop all of them for the best price. Make sure you "Search by Part Number" when looking up the part. This shouldn't cost more than $20. If you do not wish to order on line, take the part number I provided and go to your nearest appliance parts retailer. This is a common item they should have in their inventory.
If you have questions along the way, please let me know. I hope you find this information helpful.
Posted on Mar 03, 2009
Anonymous
  • 100 Answers
SOURCE: spin cycle not working,
sounds like you have a broken motor coupling between the motor and transmission
Posted on Mar 30, 2009
chris weier
  • 82 Answers
SOURCE: Washing Machine wont spin/agitate
The most common problem is the lid switch. with a screw driver in hand open the lid and press down on the lid switch. sometimes the mounting screws will crack the switch housing and the striker can't move the actuator far enough. I am interested in the clicking noise, as this could indicate a pump issue or a sock seizing up the tub.
Posted on Jun 14, 2009
1helpful
Whirlpool heavy duty extra large capacity washer,washes, water drains, won't spin, makes a humming noise (not loud) when trying to spin
Are you sure it’s agitating? If it isn’t agitating or spinning, then motor coupler is most likely broken. If it is actually agitating, but not spinning, clutch may be bad or article of clear thing could be lodged between basket and tub.
Whirlpool Washer Model No. LXR-1564039, Serial No. CM-1564039, Type 107, Year 2006. Went using the extra large setting the washer leaks water from the bottom, however went filling for the rinse...
Although its difficult to say the problem may not be caused by the amount of water but the water temperature.
Most often rinse tempertaure is cold only, however the wash might be warm /hot. A great place to start would be when the machine is filling in wash watch the connectons from the taps to the machine for any leaks in the hoses or connections.
Hope it helps.
3answers
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
1helpful
I have a heavy duty large capacity Whirlpool LLR6144BQ0 washing machine and the agitator only works at the bottom can you help?
Good day,
Common problem. The top of the agitator is driven by what are called "dogs", and are worn out.
Here is an excellent tutorial on how to replace them.
The cost should not exceed $10.00.
http://www.youtube.com/watch?v=V5wIN1J70-Y&feature=player_embedded#
Thank you for using FixYa
5helpful
Won't spin or agitate
coupling.between motor and gearcase.
3helpful
Mad dog kit? Bird dog kit? Some kinda dog or somthin'?
Your model number will be located somewhere around your tub opening under the lid. The parts you are looking for are called "agitator dogs" (yes, there is such a thing). There are four of them located under the agitator cap that help grip the agitator shaft when turning. This causes the agitator to crank in one direction during the wash cycle. The part number for the entire repair kit is 2744 and costs $16.80. This includes all the washers and bushings as well as the dogs. If you just want to purchase the dogs, the part number is 3109 and costs $5.20. For a little more, the entire kit would be a better recommendation. You can get everything you need at repairclinic.com. If you cannot locate your model number, type in the brand name of your washer (i.e., Whirlpool Stylemaster Washer) in the "Search" window and you will find what you need. These parts are the same identical parts that your major appliance service companies use, but cost much less (I should know, I used to work for one of them). Let me know if you decide to repair on your own and I can give you follow-up advice on how to take the agitator apart and replace the parts you need.
10helpful
2answers
Agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
Washing Machines Logo
Top Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
