claude wingfield Posted on May 21, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2050 Add Toner signal
My Toshiba 2050 "Add Toner" signal will not go off and I cannot copy. Also takes over 5 minutes to cycle on when power switch is turned on. I just added a new toner drum. No fix. I unplugged. No fix. I turned off. No fix.
A
Anonymous
Try resetting the machine
Anonymous
Level 2:
  • Expert 163 Answers
  • Posted on Sep 14, 2007
Anonymous
Expert
Level 2:
Answers
163
Questions
Helped
88522
Points
221
Dear sir the toner cartridge is hard first take it out ,shake well then move its gear manually ,and install it agin ,toner is not going in the developer .or your toner is not original.sensor is not sensing that toner
Kyocera KM-2050 DIRTY COPIES BOTH SIDES.
Clean the feed rollers. Don't use refilled toner cartridges. Brand new OEM toner every time.
KM-2050 dirty on back of copies
Copytechnet https://www.copytechnet.com > kyocera-mita-copystar
Mar 27, 2009 - toner scatter on back of copies. I've noticed a bit of toner build up just below the drum and also a slight bit on the transfer roller. I wiped ...
KM 2050 Copying half of the page!!!!! - Copytechnet
Sep 9, 2014
KM-1650 & KM-2050 - image compression - Copytechnet
Dec 14, 2011
kyocera mita km2050 dirty toner at the back of paper
Sep 25, 2020
Miscellaneous KM-5050 faint copies. - Copytechnet
Jun 3, 2015
More results from www.copytechnet.com
2answers
Toshiba estudio 2006 backgrond dark in print copy.please solved thise problem
Did you use the original toner and original drum? Toner high in developer. While pressing [0] and [5] simultaneously, turn the power ON. The following message will be displayed. Key in code [2000] and press the [START] button. The display changes as follows.
Indicates the controlled value of the auto-toner sensor output. Press the Up or Down button to change the value.(245,128)
Please the OK button.
Hello sir copier Toshiba e studio 600. when I turn it on it shows 19 vertical lines standing in the screen display. Also it is still warming up .it makes me not able to copy . Please help me. Thanks
Display panel is properly shot. as warming up. try taking the toner bottle out after powering off. then power it on without he toner bottle let it go thru its cycle when asks for toner install
try this site for additional info
Toshiba STUDIO 520 523 600 623 720 723 850 853 Service Manual free...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1helpful
My Ricoh Aficio MP 161 said to add toner but still won't copy
Check your old toner bottle and make sure the plastic "cap" is still in the bottle. These machines have an occaisional problem with the caps coming off (not the black screw off cap but the semi clear cap under the black screw off cap) and staying inside the black plastic "cup" that you insert the toner into. If the cap is missing it may be stuck inside this cup. If the cap is still in your old cartridge then try opening/closing the front door and letting the machine cycle to see if the toner light goes out. May have to do this several times. Had one customer just yesrday have to do this to clear the toner light after adding toner.
Good Luck.
Minolta copier 2050
OK CAREFULLY take out the toner bottle, then open close the front door, then power off the machine, wait 10 sec, then power the machine up with the toner bottle out, only add the bottle when it ask for toner
1helpful
2answers
Konica 7020
F26-1 at power up. [Description] F26-1 at power up.
[Solution]
PROBABLE CAUSES:
1. The TDS (Toner Density Sensor), in the developing unit, has detected a depletion of toner.
Note: This may have been caused by the customer making an excessive amount of copies while the machine was out of toner. It may also be caused by a bound toner addition system.
Clean all toner from the toner recycle and toner supply assemblies. Confirm that the gear mesh between the toner supply auger drive gear and toner supply motor (M4) is flush. If toner supply conveyance is normal and the toner cavity is empty, install a new toner cartridge (Item #950236) and then perform the following diagnostic mode to replenish the developing unit with toner:
a. Access the 47 mode (power the copier ON while pressing the 4 and 7 keys).
b. Enter output code 54.
c. Press the START button.
Note: Toner will now be added to the developing unit and stop automatically when target level is reached, although it will not run any longer than 3 minutes.
d. Power copier OFF/ON to return to normal copy mode.
Note: Perform the following 25 mode software switch settings to minimize the amount of copies that can be made, prior to copy inhibit, when the ADD TONER message is displayed:
- Access the 25 mode (hold down the 2 and 5 keys at power ON).
- Select [1] (SOFTWARE SW).
- Using the up and down arrows, scroll to the following software switches and set them as follows:
a. 4-0 set to 0
b. 4-1 set to 0
c. 4-2 set to 0
d. 4-3 set to 0
- Power OFF/ON to return to normal copy mode.
Notes:
A. These setting will allow the ADD TONER message to be displayed immediately and only allow 100 copies to be thereafter.
B. Copier inhibit will automatically be released when a new toner cartridge is installed.
2. The toner conveyance gear is worn. The toner conveyance gear is driven by the toner supply motor located on the toner supply unit.
Replace the toner conveyance gear (p/n 26NA32680).
I may be able to get the manuals for a nominal charge. [email protected]
Kyocera 2050 Has set toner error
Take out the toner and clean all contacts that you see. and make sure that it is seated properly. if the contacts are not touching it will not see the cartriage.
Toner low signal
Try turning your copier off & back on. Allow the machine to cycle after turning it back on - until it comes to ready or displays add toner signal again. You can try this three or four times as it sometimes takes the machine a few trys to advance the new toner to the toner sensor. If after 4 attempts you are still getting the add toner message - you may have a dirty or faulty toner sensor. The toner sensor is located inside the developing unit that you are loading toner into. Toner sensor is usually located on the bottom of the developing assembly & is held in by 2 scews. It can be cleaned with a dry cotton rag & reinstalled. 90% of the time power cycling the copier a few times will solve this problem.
Top Toshiba Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
