it could be possible that changing the dc jack at the back may fix the problem however it could be a faulty new battery as ive had a few copies (not original) which would work for a week or so then die or others which wouldnt work at all, i finaly splashed out on a new original battery and it hasnt let me down and i bought it over a year ago.
You could have a corrupted program on your PDA. You need to contact HP and have them re-flash or upgrade the firmware of your PDA and it should work much better than before.
switch the hard switch off in the back of the ps3. unplug power cord... press and hold power button located on the front f the ps3 for approx 10 secs, then let it sit for a few, then hook it back up and turn the hard switch back on and try to power it back up.
I have had this happen once before but it did return to normal.
Ok not turning on is kind of vauge. This is what I would recomend trying. First off pull the battery and put it back in it should automatically boot in about 5 seconds. If this does not work use the power button slider on the side of the phone. If that does not work use your stylus in the reset button found on the bottom of the phone on the left hand side this should restart the phone after you remove the stylus. If that dosent work you can do the master reset and try that. If that dosent work I would say that you are out of luck with your phone.
