Hitachi Travelstar 80GN 60 GB Hard Drive Logo
Question about Hitachi Travelstar 80GN 60 GB Hard Drive
Him I need to recover data from an Hitach Travelstar HDD N155 ? Is it a SATA ? Do I need to connect it to a pc as a slave using a cable ? Which kind of cable ?
Posted by michel_lucza on
  • Anonymous Mar 31, 2014
    what power cord can i use?
Anonymous
    President:
  • 2,992 Answers
This drive is an IDE type and not SATA, which means you will need an adapter like this one so you can plug a data cable and provide power. You can then connect the drive to a regular desktop PC.
You can set the jumper on the drive to make it a slave and hook it up on the same IDE cable as your primary hard drive, but the jumpers on the laptop drives are teeny little ones and I personally find them hard to deal with. What I do is unplug the data cable to the optical drives which are on the second IDE channel, then plug the laptop drive cable there. Then the drive can remain jumpered as master.
Another option is not to bother opening the PC at all, but to get an external hard drive case like this. Then you could just plug the drive in on a USB port and copy your data, and you'd have an external drive available for future use.
Good luck with the recovery, and thanks for using Fixya!
Posted on Dec 04, 2010
How to drill a travelstar n155 hd to destroy it?
Hard drive disks (HDD) have multiple spinning platters that data can be extracted from, even after attempts to destroy it. If you are serious about destroying a HDD, then contact a professional HDD destroying company. They actually shred them. If you are hell bent on doing this yourself, you can try to drill into it, all the way through, MULTIPLE times... But you are doing this at your own risk and the data may not be sufficiently destroyed. killDisk is another tool you can use to aid in the process. A simple search will lead you in the direction... But again, at your own risk!
I have a samsung hdd unfortunately so i was moving things from a wd hdd to the samsung one g2 500gb then the hdd wouldn't open and it asked me to format it and said something about a cyclic...
Hard disk drives are not generally that prone to failure unless they have been used for two or three years or your computer is switched on 24 hours a day, seven days a week. Before you even try to recover your data, you need to make sure your computer is not causing the problem. Are you connecting the HDD directly with a SATA or PATA cable, or is it connected via a USB cable?
I would try the HDD on another computer first (if you have one or you have a friend who will let you use their computer). If the drive still cannot be read on another PC then you will need to find a suitable data recovery program such as http://www.aidfile.com/ or Easeus data recovery http://www.easeus.com/ and see if you can recover your data from the drive. I would not use your current PC for this process, but use another PC (or a friend's PC) just in case your PC is faulty.
After you get your data recovered (if possible) , the HDDs which do not work on your PC should be formatted and tested on another PC to see if they are really faulty or if it is your PC which is causing the problem.
2helpful
I have two hard drives in my tower How can I make it boot so that both hdd show in one os And it goes straight to windows
Windows will see both hard disks when Windows opens up.
For IDE/PATA hard drives the boot hard disk (C drive) must contain the Windows operating system and it must be jumpered as the Master drive. The other hard drive must be jumpered as a Slave drive if it is on the same data cable as the Master drive.
After Windows has been installed and this Slave drive has been partitioned and formatted Windows will see this hard drive as D: Drive which can be used as data storage etc.
If you have SATA hard drives you need to connect each SATA hard drive on its own SATA cable/controller.
Will a Quantum Fireball hdd replace a Sata hdd.Both are 3.5 and 5/12v or do you need to re configure them?
SATA (serial ATA) is a connection type, not a brand of hard drive. Any brand of hard drive will replace any other, as long as they are both SATA drives. The data and power connections are standard between drives, as are mounting dimensions. Normally, with SATA drives there are no jumpers or other configuration you need to deal with. Each SATA drive has its own connection to the motherboard, so you don't need to set master/slave jumpers like you would on the parallel ATA drives using the wide data cable.
Samsung HDD does not get detected any more. I have very important data and want the data to be recovered at worst case. HDD is old one and makes strange sound when connected. Even if I connect it in...
Try to connect it as a master. Just connect this hdd only, so we can know if is detected in the bios. If yes then there's a possibility that you can recover your data. If you hear clicking noise/strange sounds then there's also a big chance that your hdd is broken. If it is detected in the bios, then remove it again and try using an external casing so you can put this hdd in it and connect it to your pc thru usb. I assume that your hdd is an ide and not sata since it's old as you say. Then to go to windows and see if your hdd in external casing is detected. Another option is that if it is detected in the bios, use a bootable cd with software apps for Hard disk tools like HDD Regenerator or HDAT2 to check and repair bad sectors on your hdd. Use this at your own risk and may destroy all data on your hard drive. If noe of this works, then you can assume that your HDD is not functioning anymore.
3helpful
5answers
The hard drive is not being detected on our laptop it turns on and everything but its not being detected what is the problem its not even a year old yet.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
http://www.asoftech.com/adr/
1helpful
3answers
Connected IDE Drive does not mount on desktop
ASUS K8V-MX Motherboard with 250GB SATA HDD and 250GB IDE HDD Problem
Hi LP,
I’ am very familiar with ASUS motherboards. I am thinking you have posted two questions or more referring to the,
ASUS K8V-MX board. When you sign into you're FixYa account you than need to click on you're profile. Within you're profiles are the questions you have posted. Click that question to add or see the expert's answer. If you need another question (about the same item) re-post within that same question. You can even copy the link to an older post & past that link into you're next question. (Than I can read you're last question & my responce).
LP you have me all mixed up. I'll answer the question you have posted above. In the future please provide you're old post so I understand better.
There is nothing wrong with IDE 250GB drive or the SATA drive.
The problem you are haveing is setting the correct settings.
The ASUS K8V-MX can support two serial ATA SATA drives. The SATA drive's can only run at 1.0 version. 1.5GB transfer speed & not SATA II, the 3.0GB speed.
How to setup the SATA drive?
Please disconnect any other drives (IDE) & a second SATA drive that may be connected to the system. Except the CDROM drive.
Using you're manual the SATA drive should be connected to SATA1 port. Page 1-24 in you're manual.
Put you're windows CD into you're CD-ROM drive & boot the PC. You will see, Press any key to boot from CD... (press any key on your keyboard). Windows will start to install. Durring installation of windows the system will restart. You will again see, Press any key to boot from CD... (DO Nothing)!
Just allow windows to conintue on its own. Windows will continue to install it's self. This will happed once again, & again do nothing. Windows will finish installing it's self.
After windows has finished, load the ASUS CD into you're CD-ROM drive & install it's driver software. Restart the PC.
You must register windows. Do so.
Than update windows through windows update service. (This will take some time to complete). (Do not install service pack 3).
If you have an IDE drive 250GB in size & you installed windows on it. You must erase the drive or it will conflict with you're new installation on the SATA drive. To do this, look on the IDE drive & you will find a large white sticker. Printed on there is instructions of how to set the drive pin. Set the drive up as a slave drive. (This is only temporary).
Power off the PC & unplug the power cord. Connect the 250 IDE drive's power cable & data cable. Plug in the power cord to the PC & turn on the PC. Windows will load. Right click once on the start button & slide up to & left click on Explorer.
Find the 250 IDE drive, it should be drive letter D or E. Right click the proper drive letter & format the drive.
( Do Not format, Local_Drive C:\ ). Once the format is complete, power down the PC by clicking on the start button & click turn off the computer. Once off, unplug the power cord. Change the pin on the 250GB IDE drive to Master with a slave. Take the 40GB drive & change it's pin so the 40GB drive is a slave.
Connect the 250GB drive to the end of the IDE data cable & connect the 40GB drive to the next connector of the same IDE data cable. Re-check all power cables & data cables for good connections before closing the case. Plug the power cord in & power up the PC. Everything should run just fine.
Setting the pin for you're IDE drive's can be very confusing. Click on the link below. This will give you an idea of how to set you're pin for a master drive, master with a slave drive. If you post the name ST****** of you're two drives I can post the correct pin locations from Seagate's web site.
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
Have more questions about this post?
Mike
Samsung 80 gb Hard Disk Un allocated
All ways best to used new cables (sata/Ide) I like to set jumpers on the HD's never cable select. Also try installing one harddrive at a time. Second make sure in bios is set to boot from main HD.
Top Hitachi Computers & Internet Experts
Marvin
Marvin
W.L.
matt
matt
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
