The computer collapsed. I try to format the hard drive and re-install Windows XP. However, it cannot go through and found another blue screen with technical information: STOP: 0x00000050 (0xE579D868, 0x00000000, 0xF77E3E4C, 0x00000002). How can I fix it? I tried installing xp again but it won't let me through. I tried boot up disks but that didn't work. I tried using a disk to scan the memories but it only gave a missing ntldr error. I'm at a loss at what to do. Help would be much appreciated.
Re-install Windows. Clean install works best, but all data will be lost.
Thanks Jose. I have removed all attached cards and original two memory Ram. I put a workable Ram to test each slot at a time. Every time come out the same result of blue screen with same Technical Problem information. Besides, I also have hard drive test and found there is no bad sector. The hard drive has been formated and only left HP partition in the Hard Drive now. Any suggestion?
SOURCE: Windows XP Blue Screen
change your ide cable or sata.
Reset your bios settings pull cmos cell from motherbord for minute so all settings are defaults.
Also boot your computer with winxp disk then if you able to enter in setup then go to recovery console mode and run "chkdsk /r' command .
Also check your harddisk is master set jumper in master position .
SOURCE: ntldr error on ibm intellistation z pro w/ xp pro
When you format the new hd, do you remove all partitions and create one afresh? That could be the problem as i have seen this happen before
SOURCE: error message NTLDR missing on formatted hard drive
You need to either reinstall windows, or take the hard drive out, hook it up as a spare drive to a working computer and copy NTDLR to the root of the laptop hard drive. It would be much easier to reinstall windows. You can always use the recovery portion of Windows, but if I were you I would just do a format and reinstall. NTDLR is just a startup file for Windows XP, that does not mean your hard drive is gone or anything. Please don't forget to rate!..Thanks
SOURCE: FATAL ERROR MESSAGE/DELL OPTIPLEX GX150 DESKTOP/WINDOWS XP PRO
Optiplex 150 I get a message error loading operating system
can somebody help out there?
SOURCE: Intellistation Dreaded "ntldr not found"
You have the solution given the fact that the IBM netloader wants to be subordinant to a loaded OS on a different drive acting as server when used on a thin client like the Intellistation. Unless carried as a portion of the registry of an MS OS, XP or Vista will drop it unless registered with a NetUpdate as a standing part of the registry. But most sysops conduct updates without all clients active so that some will inevitably be dropped, which is why the best strategy is to conduct updates on Off Hours when all clients can be up without human interaction, impossible during the workday, unless you deactivate an entire set of nodes for the purpose.
Run a reregistry while the Intellistation is on and active but without an operator and your problem should disappear more permanently.
How to Fix:
To fix STOP 0x00000002 error you need to follow the following methods.
