Try turning it off and urning it back on if that dosen't work i am sorry to say but your tv is broken parallel lines normally means that the color scheme for the tv is either not correct or is damaged as long as you didnt change any settings i am almost positive it is broken.
These lines are caused by broken or leaking capacitors. This TV will require servicing.
SOURCE: Vertical lines on screen when viewing
If the lines are there all the time or intermittent but in the same location it is an indication of a bad panel. The panel driver can also be the cause of this symptom. Samsung panels have had issues with the connector that carries the LVDS signals to the panel itself, this is not serious and can be resolved and little cost. Joe Weibel
SOURCE: Vertical bar on Daewoo Plasma screen
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me [email protected]
SOURCE: Thin Yellow Vertical Line - Samsung LNT4665F LCD TV
Unplug for 30 seconds from it's power source and then try it again. If that doesn't work, call Samsung for further troubleshooting and have your model number and serial number handy. Please be prepared to tell them how long the line is.
SOURCE: Black vertical line 2" wide with a very thin green line
The black vertical line is caused by a leaking capacitor, Check and replace poped capacitor with a new won and it will work fine again. No worries.
Thanks for using fixya.
SOURCE: Vertical line on LCD TV Panel
No solution here.
I have the same issue... A vertical magenta line, about 2 pixels wide, appeared about 1" from the left side of my 52" LNT5265FX/XXA. Of course, this appeared after the 1 year warranty... For me it started showing up about 22 months from purchase date. It goes away when the TV warms up after about 30 minutes or so. Sucks that such an expensive product has developed this issue w/in 2 years.
