Samsung HP-R5072 50 in. Plasma HDTV Logo
Question about Samsung HP-R5072 50 in. Plasma HDTV
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Otherwise, we have never had any problems with it. It has always been moved upright, but it hasn't been moved for over a year.
Posted by Sarah Turner on
Claude Kayser
    Top Expert:
  • Samsung Master
  • 9,098 Answers
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Posted on Dec 19, 2015
I bought an LCD Samsung 3 years ago and about a year ago a thick black line appeared in the middle of the screen. Can this be fixed at home?
check if the lines appear on different inputs or source like hdmi,av,pc, if it happens on a different source then theres a problem with the lcd screen it needs to be fix.
Horizontal line on screen sometimes
Generally horizontal lines are caused by the panel failing, you can try a new tcon but I don't think it will help.
1helpful
We can hear it but the picture is very narrow in the middle if the screen
If you are referring to a horizontal line or bar, you will have to resolder the vertical IC. You may also need to replace the electrolytic capacitors that are almost next to the same IC. Now if you have a black vertical bars on the left and to the right side of the screen, you have a horizontal problem. Bad electrolytic capacitors and bad resistors in the horizontal deflection area of the TV board! Thanks for asking and give me a few hands of support!
Mitsubishi CS-3515R tv problem
is locked and forgot my 4 digital code number
Horizontal Lines On Screen
horizontal lines = horizontal sync off . mitsbishi always seemed to have this problem .. on the older sets I would take the back off and inside deep on the board i would adjust a pot and sync it right .... and never had a recall, maybe your newer model has this too .. this little control,
but its a horizontal sync problem.
if no change the horizontal processing ic.
2answers
Picture/image problem
Bad solder connection in the horizontal pincussion circuit.have someone resolder.God luck.4tune
1helpful
Horizontal lines on NEC plasma
Intermittent horizontal deflection
Resoldered the pins of horizontal deflection transformer
Picture is horizontally narrowed and deformed
Capacitor C2913 (390nF, 250V) on the deflector PCB had lost capacity
Geometric distortion, Pillow, and picture enlarged horizontaly
The problem was a short from GND to pin 11 inside IC301 (TDA8350Q). This pin is the output of amplifier for geometric correction signal. Replace IC301
Black screen, high pitched squeal
A set that has only a 1/2 inch bright line through the middle of the picture, from left to right, has a vertical output IC that is not working correctly. If the 1/2 inch line is in the middle but going up and down, then the horizontal yoke circuit has stopped working. These are problems which should be looked at by a qualified tech, but if the set was purchased 6 months ago then it should still be under the manufacturer's warranty.
 Grubhead
Grubhead
