Watches Logo
cris Posted on Oct 13, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to know how to change the analog time and pronto please:(
Mandeep Singh
Level 3:
  • Master 1,184 Answers
  • Posted on Oct 13, 2012
Mandeep  Singh
Master
Level 3:
Answers
1184
Questions
11
Helped
474835
Points
3414
As you have not mentioned the model number for the Gshock , i'm sending you the link for the user manual. Select the correct model number from the list and follow the steps to change the setting as per the manual. In case there is a problem , share the model number for the watch i will help furthur.
http://mygshock.com/casio-manual/
Thanks for using Fixya
Proton
To be able to change to analog time from military time
Go to your events/calendar. Click the little settings symbol there. Then uncheck 24-hour time and save. How do I change my clock settings from military time to regular time.
just found this on the internet dont no if this will help you out if not let me no.
2answers
How to set analog time for casio SGW 400 h please help
Analog time follows the digital time on Casio watches.If this is not happening,try the hands "set to 0" procedure using the manual.
2answers
The watch shows time in digital plus has hands on it like a regular watch the digital shows one time and the hands show another
Hi jessestaton,
All you would have to do is change the time from either the digital mode or the anolog hands , you can choose one which is incorrect and try to change it.
Now to change the analog clock's settings , you would have a button which you can manually rotate and set the time, this is how you would be able to recognise that it's for the anolog time modification.
If you need to change the digital time , all you have to do is find out buttons that are present on the watch , and then try to change the time.
Note:- If you find a circled knob , remember that could only be for anolog time change as digital time is never changed using such knobs or screws , but have seperate button for that function.
In case you have any queries, feel free to get back.
Hope this helps ..:)
Jun 12, 2011 • Watches
20helpful
I have a casio ediface 5033 80W-M10008 how do I set the analog time
Thank you for contacting FixYa.
To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Best regards. Jewel
5helpful
2answers
I accidentaly reset time & date on my square arnette watch and i need help to set it
    Set Digital Watch
  1. Press and hold the "Mode" button on the right side of your Arnette digital watch for three seconds to change the watch's mode. Press and hold the "Mode" button repeatedly until flashing digits indicate that you have entered the watch's time-setting screen.
  2. Use the top and bottom buttons on the left side of your Arnette digital watch to increase and decrease number values as desired.
  3. Press and hold the "Mode" button repeatedly to exit the time-setting screen and return the watch to time-telling mode.
  4. Set Analog Watch
  5. Pull out the watch crown on the right side of your Arnette analog watch.
  6. Turn the watch crown clockwise to adjust the hands of your Arnette analog watch to the appropriate time.
  7. Push the watch crown back in when you are finished setting the time on your Arnette analog watch.
Best regards. Jewel
Sep 09, 2010 • Watches
22helpful
How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
Setting Digital Time
  1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
    Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
    Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
    After the time is set, press the upper left button to exit the digital time setting function.
  2. Setting Analog Time
  3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
6helpful
I have a Timex analog Indiglo watch and need to change the date
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals.Rate me, please.
7helpful
2answers
Cant se time Citizen 8988-q02047 HSB wristwatch
In the time mode, press the upper right button for 2 seconds and the time display will flash. Then press the same button untill the entire time will flash, or both hour and minutes flash at same time. When the hour and minutes flash at same time, this adjust mode is the adjusting of the analog left display (A1). Now, press the lower button for adjusting de hour shown at the digital display that shows the same hour at analog display. This method is to adjusting the 8982 that is the "father" of 8988. Like a Citizen collector, and don´t know any website that you can view the setting instruction of 8988, only the 8982 is disposable here: http://www.citizenwatch.com/downloads/techguides/8982.pdf
2helpful
Casio G-Shock G-7400 Watch
Thought this would happen when I sent you a request to help me simply change the analog time on my watch.
Your repsone to free suppor tis asking me to enter into a arrangement that requires payment.
I've solved the problem from another site free of charge.
I'm very disillusioned with the way you promote your site and will definitley recommending to others to stay clear of it.
COmes across as we can help you free of charge but bottomline is that this won't happen.
Onlty wanted to know how I change the analog time on my watch - could go to the Jewler to do this free of charge - thought the internet would help but your company has prolonged the support immensely.
Regards,
Paul Stirling
874helpful
11answers
Casio telememo 30 syncronising analogue and digital time
To set the analog time to match the digital time...
There are 4 buttons: top left=A, top right=B, lower left=C, lower right=D
Get the watch in timekeeping mode (where it shows the digital time or date)
Press C six (6) times
Hold down A until the current digital time begins to flash
Press D repeatedly to advance the analog time, one minute at a time.
If you need to advance the analog time at high speed, HOLD D DOWN.
To return to regular timekeeping mode, press C
Set the digital time so that it matches the analog time, since you can reset the seconds easily.
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
