I want to use the router as access point by linking to a live box
SOURCE: Forgot Access Point Password
All you have to do to reset the password on the router is to reset the router. You just have to find the reset button and hold it for about 15 seconds. If you have any problems with reseting just look at this pdf.
ftp://ftp.linksys.com/pdf/wrt54g_ug.pdf
SOURCE: D-Link DWL-G700AP Access Point
You need to connect the access apoint directly to a pc with a CAT5 cable then set up a static ip on the pc which I assume you know how to do it, for the static ip put 192.168.0.5 subnet is 255.255.255.0 and gateway is 192.168.0.1 then save the settings, then check first if there's a good connection between the access point and pc, go to the command prompt then type PING 192.168.0.50 if you receive 4 replies go now open the http://192.168.0.50 if you receive 4 request time out reset the access point and and ping it again if still 4 request time out after you reset it replace that access point.
SOURCE: how to configure wireless device model tp-link access point p2p
AUTOMETIK CON.CHANGE D-LINK AP 2100 VERY PROBLAMS MY CONTECT NO:- 9939487245
SOURCE: How to configure a D-link access point DWL-3200AP
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
SOURCE: cant konfigure router, when i type 192.168.0.50 or
Reset using the button on the back the do an ipconfig - so if you ip is 192.168.1.1 try that to get in to the router
