Hello. My name is Dave, and I have posted a reply to your issue. I have not heard from you, so I don't know if you still require assistance with your HK. Just for your infomation, I worked for Harman Kardon, as their Technical Support Specialist. If you still need assistance, please reply. Thank you, Dave
Rescan stations. Failing jay check for localised issues involving radio transmitters as some may be affected by scheduled maintenance works. Thanks
SOURCE: No sound from my Samsung 40" flat screen tv
probably your cable or sat box malfunctioned. try unplugging the power for 2 minutes and then plugging it back in. my cablebox would do that to me all the time. let me know if this doesn't help. check sound on dvd or other sources to narrow that down.
SOURCE: just got tv yesterday, hooked regular cable wire
when you go into the customer setup menu in the channel scan area make sure the set is set to cable also us ez setup if that does not solve your problem return it
SOURCE: we are unable to receive
Digital TVs or set-top boxes only receive the digital TV signals not the digital radio signals. To receive digital radio, you need a digital radio (DAB+) receiver. The ABC does broadcast two of its digital radio music stations-ABC Dig Music and ABC Jazz-on digital TV and they are available on channels 200 and 201.
If this is helpful a vote of the thumbs up would be appreciated
Register and download the manual for free audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/harmonkardan/avr_110.html
Hello. When you use the scan button, does it just scan 88-108 and continue? Are you using the supplied antenna, which would be a dipole antenna? Did the FM ever work correctly? How about the AM? Will that receive channels?Thanks
