my t.v was working..but in display the blue lines are showing.. pictures are not seen.. only blue linesmy t.v was working..but in display the blue lines are showing.. pictures are not seen.. only blue lines
You can't post conmments that contain an email address.
What is the problem with this set? Provide more details please. Visit the site named 'Electro-help' for
more details. Click this link. View it in
'Flip card' option, which can be selected from the drop down box
menu by the [Sidebar] tag, at the top left corner of the display
window. It will make search easy. Some times, the ads attached with each
posts, both at the right and bottom, might help you to find the availability of
spare parts. There are more than 870
posts to different brand TVs now.
Looks like the AV port in your Philips television is busted. It's the only factor if the Wii is able to function with other tv with the same cable. You can either purchase a new television/get the one you have fixed (these will cost money) or you could just purchase an hdmi cable which doesn't use the same port so it could possibly work with your Philips television.
On this page I found listed under "Software & drivers" the Firmware Upgrade Software 42PF7220A/37 v1.5.0.0
I downloaded the compressed file and extracted it to a USB Flash Drive. After you extract the file you will have 2 files...."autorun.upg" and a "readme.txt". Print out the readme file the delete it off the USB Flash Drive Make sure the USB Flash Drive has only one file on it (autorun.upg)
Then just follow the instructions from the "readme" file.
Make sure the TV is turned off.
Put the USB Flash Drive in any of the USB ports on the TV.
Turn the TV power on with the Power Button on the righthand side of the TV.
The TV will display an Update screen.
Let the TV run through all 3 processes.
Turn the TV off and remove the USB Flash Drive.
Power the TV back up.
Hopefully the Updates fixed the problem.....
service manuals cost around 14.00 online -- you can download a free owners manual from philips.... the flashing lights are a protection code
one flash / pause / two flashes
this means that there is a problem with the software -- this television was probably made in 2006 and in 2007 - they had to supply customers with an upgrade to the software -- you can download it for free on philips/software/support.com
look in the section - drivers/software---- put it on a thumb drive and install into the USB port on the right side of the television--- the television will come on and scan for the software----
