Philips 42PFL5332D 42 in. LCD Television
Problems with Philips 42PFL5332D 42 in. LCD Television?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Philips 42PFL5332D 42 in. LCD Television RSS Feed
View More Results for Philips 42PFL5332D 42 in. LCD Television
Questions and Unsolved Support Problems
Unsolved Problems for Philips 42PFL5332D 42 in. LCD Television RSS Feed
Answer
I have a new Philips LCD TV: "47, model PFL 8404H/12, everything was fine until last night,... (More)
Answer
philips 42pfl5522-lcd blue screen, remote control will only turn up the volume on screen when any... (More)
Answer
my 42in ilo will not scan the channel that are between the other channels
Answer
I have a problem to use the TV like a pc monitor. What I need to do?
Answer
I have a Philips 42" LCD flat screen tv, sorry do not have the exact details to hand, but i... (More)
Answer
Philips 42" lcd tv powers on has audio but no video.
Answer
My Philips 42PFL doesn't have a very clear picture, there is always a light haze on objects and... (More)
Find a Manual
Philips 42PFL5332D 42 in. LCD Television Manuals & Guides
Tips & Tricks
(Post a New Tip)
Lamp vs Ballast
This is to help explain the short lives of Lamps. WARRANTY: If a lamp fails within the first year replace Lamp and Ballast. If Lamp explodes do not... written by BIG IRISH
Polaroid flm-373b lcd tv black screen control box no power fix
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked.... written by stiv0
Enter expert mode on LG TV
For the 44" LG DLP model RU44SZ63D...press and hold the menu button the remote control until a four digit password is requested on the screen.... written by mlapres
Tv troubles
the newer tv are just computors in disguyes.they often won't come after a power surge and have to be reset,you must unpluge from the wall and wait 10... written by bsddog87
Falt Panel Screen Cleaning
If you are trying to clean a LCD or Plasma screen, use only recommended screen cleaners. Be very careful not to rub too hard or contrast coating may... written by edcor
TV has snowy picture or displays unusable signal, no signal or no sync.
What to do if you have an all snowy picture, blue screen or the TV displays unusable signal, no signal or no sync. When using a Satellite receiver or... written by johnnydiode
how to test flyback without taking it out of the board
a) basically it has to be acted upon by a supply voltage of at least 95V to work. b) of course, assuming the horizontal deflection oscillator works,... written by palaboy
LCD Flat Screen Common Problems
Have you ever wanted to know what causes a nice LCD to give out so soon? Poor electronics components such as Capacitors. I will tell you how to spot a... written by rulds2008
WikiManual
(Post a New Chapter)
How to Mount a Plasma TV on a Wall
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's... by wikihow
How to Connect a TV to a DVD Player Without A/V Jacks
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Philips 42PFL5332D 42 in. LCD Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Ratings for the Philips 42PFL5332D 42 in. LCD Television
Owners Recommend
out of 3
Reliability
Ease of use
Value for Money
Rate and Review the Philips 42PFL5332D 42 in. LCD Television
Write a review:
Rate this product:
Would you recommend the 42PFL5332D 42 in. LCD Television to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Philips 42PFL5332D 42 in. LCD Television
Key Features
Screen Size
42 inch
Contrast Ratio
600:1
Flat Panel Type
LCD Television
Display Resolution
1366 x 768 pixels
HDCP Support
With HDCP Support
LCD Response Time
8 ms
Connectors
Front Input Connectors
Audio (RCA) x 1 · S-Video x 1 · USB Port
Display Capabilities
Built-in Tuner
NTSC · ATSC
Broadcast Format Supported
1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 480i (SDTV)
Broadcast Format Displayed
Native Aspect Ratio
16:9
Image Quality
Brightness
500 cd/m
Viewing Angle
176
Philips Contact Information
Main support number1-888-PHILIPS
Describe your problem:
Top Flat Panel... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
