My router was working find one day now it is sending a signal being picked up my my laptop however my laptop says "no internet connection". I have bypassed the wireless router and get signal straight from the modem but can get internet from the router anymore?
The best way is to get a data cable and connect directly to the laptop. Your laptop should recognize the router and prompt you to make this your wireless device. Once through the setup you can unplug the cable and you should be set for wireless again. The one other thing to check is make sure the wireless button on the computer is on. Mine is on the front but I have seen them all over. Check the latter first.
SOURCE: Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
SOURCE: di-524 dlink; wireless laptop connects but no internet or network
Your wireless card is dead, replace.
SOURCE: Problem between my Qwest actiontec modem and D-link router
You need to sign into the dlink router and check the status tab, to make sure that the router has picked up the modems IP address. it sound like it hasn't, and is just assigning lan IPs to the client machines, butd oes not have a valid WAN IP to the internet.
If it hasnt got a wan ip, you want to do a hard boot on the router .unplug the router ONLY for 30 sec, and power back up the router only ...not the modem this should allow the router to find the modem IP
SOURCE: Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
SOURCE: router randomly stops sending out wireless signal
You may be getting interference from other routers in your area.
Check to see what channels the other routers are broadcasting in your area, change it to a channel that is not being used.
The location of the router could affect the signal strength, move the router away from concrete reinforced walls etc, and or move the router to a higher position in a clear space.
The radios used for WiFi communication are very similar to the radios used for walkie-talkies, cell phones and other devices.
you need to connect your desktop to the router via RG45 ethernet cable.
was this helpful ?
