The passenger window will go down fine. It goes up a 1/4 of the way then stops. If I give it a few minutes it may budge a 1/2 inch up again. Then the same until it finally gets to the top. S going up seems to be the problem. It seems to have power to the motor though. I've heard maybe the window regulator. Any ideas?
Take the window down all the way and spray soapy water in the window sealing tracks if it goes up easy thats where the binding is. some times with age the rubber comes loose and will cause a bind. peeling window tint sheeting will cause this as well,worst case mechincal problems in regulator or drive motor
SOURCE: 2005 Chrysler Town & Country. Passenger side window problem.
HAVEK 1005 sounds right on track.... but also try this, usually works well for non functional power windows, specially Caravans.
NO COST PROCEDURE TO FIX IT:
1. Sit in vehicle, on seat next to problematic window
2. Ignition key is on
3. Door in question is opened (in case you closed it)
4. While door is open, press and hold power window button in desired window travel, keep button pressed !!
5. SLAM hard the door closed with one hand while other hand holds button as per #4.
6. Watch window operate as it should.
7. Repeat 3-6 if necessary, but usually the first try works!
NOW, for the naysayers that says you must replace power window motors etc, at $$$ cost because the above fix does not work, or is not long lasting fix, or less than a "professional fix".... Well then, when the window fails to operate again, apply same fix again at that time.
I have fixed my van this way numerous times (usually once a year), and to all local friends I recommend this fix too, likewise do the same and are happy with the solution.
SOURCE: Power window does not work
you need to buy or make a clip removal tool. it looks like a sturdy 2 prong fork to pry off the plastic clips.this id whats holding the interior panel and some screws holding the door opener
SOURCE: Describe your 2005 Chrysler Town & Country electric windows.
window cable is breaking. replace window motor and cable assembly.
SOURCE: 2001 Chrysler Town and Country Window problem.
it could possably be the motors for the windows are bad
