Re: cant access the fade controls. Rear speakers are not...
When the rear output setting is "rear s/p:SW", you cannot adjust the front rear spreaker balance. Go to the rear speaker output from function and select "rear sp/full".
There is no fuse to the speakers your rear speaker wires should run under the kick plateon drivers side broken or disconnected wire or burned out channel in radio.
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers
The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals).
Setting the Extra Speaker Terminals
Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver.
1. Press the On Screen button on the remote control to enter the On Screen Menu.
2. The On Screen display should be displayed on the TV/Monitor.
3. Press the Arrow Down button on the remote until Setup comes up in the screen.
4. Press the Enter Button on the remote control.
5. The Setup Menu will come up across the TV/Monitor screen.
6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker.
7. Press the Arrow Down button on the remote to select Manual Setup.
8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu.
9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up.
10. Press the Enter Button on the remote control to enter Power Amp Assign menu.
11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted.
12. Press the Arrow Down button on the remote to select 7ch+1ZONE.
13. Press the Enter button on the remote to select 7ch+1ZONE.
14. Press the On Screen button to exit the on screen menu.
To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver.
Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
One way of proving it ISN'T the amp circuitry is to remove the pre-main jumpers and jack in a source that has its own volume control (or try a CD that starts really low) because this bypasses ALL the amps controls. If it sounds ok (albeit LOUD) I'd suspect oxidized contacts on the controls. Turn it off and vigorously operate all controls a zillion times to wear through it. In mosty cases it's the unused controls that fail because they never get wiped. Maybe a shot of contact cleaner on those you can access.
First make sure that the green green/black and purple purple/black pairs of wires are properly connected to operate the rear speakers.
You can check and adjust the "fader" and "rear volume" settings from the front panel. Go into settings by pressing the CONTROL knob. Then press CONTROL repeatedly until you get to the setting you want to check or adjust. When the display reads "R-VOLUME", turn the CONTROL knob from 0-35. Press CONTROL repeatedly again until the display reads "FADER" and turn the CONTROL knob from Rear 15 - Front 15 until you get the setting you want. Exit audio control by pressing any button.
The "non-fading" output may be turned ON or the rear output may be set to R-SP:S/W or both.
Press AUDIO repeatedly until NOFAD:ON appears in the display. Press DOWN button to turn non-fading output OFF. Also make sure that the setting for the rear output is set to R-SP:FUL and not to R-SP:S/W.
Your front speakers are more than likely blown. They make all kinds of different models and price ranges to look at. This gives you a good opportunity to upgrade your stock speakers to handle what your throwing at it.
Press the audio button (A button in right hand upper corner) till you see FADE or BAL press the up down or left right arrows to adjust the fade and balance till all your speakers work.
If they still dont work, check the wiring at the speaker and the wiring behind the head unit to make sure their properly intact and properly grounded.
Press the <<,>> button and select "Fader".
Turning the Rotary knob clockwise fades the sound to the front; turning the knob counterclockwise fades the sound to the rear speakers.
The display changes as follows:"Front XX" will be displayed where "XX" is the value from 1 to 12.
"Rear XX" will be displayed where the "XX" is the value from 1 to 12.
When fader is 0, "CENTER" will be displayed.
